查看: 1786|回复: 2
[前处理] gambit分网问题
发表于 2008-3-25 16:22 | 显示全部楼层 |阅读模式
我用gambit给体分网时出现这样的错:
Initialization failed;perturb boundary nodes and try again
Initialization failed to mesh 7 nodes.
ERROR:TG_Mesh_Domain failed with error code1.
ERROR:Tetrahedral meshing has failed for volume v-volume15
This is usually caused by problemss in the face meshes.
Check the skewnesses of your face meshes and make sure the face mesh sizes are not too large in areas of small gaps.
但我检查面没错误呀
这样的问题怎么解决?谢谢了
发表于 2008-3-26 11:18 | 显示全部楼层
看了你的说明,感觉是小体积或小的面部分网格不行,造成网格质量很差
发表于 2008-3-27 07:50 | 显示全部楼层
回复 楼主 的帖子
我也遇到过着这种情况,建议把分区划分,把小尺寸的地方跟大尺寸的分开划分。
GMT+8, 2024-11-25 18:59 , Processed in 0.062331 second(s), 17 queries , Gzip On.
