查看: 4642|回复: 6
[C/C++] 求变步长四阶龙格库塔法的c程序!!
发表于 2008-3-20 21:28 | 显示全部楼层 |阅读模式
一直困扰小弟,这里就拜各位大虾了!!:handshake
发表于 2008-4-2 00:17 | 显示全部楼层
请参阅《C常用算法程序集》第二版的P177;或第三版的P294.如果找不到这两本书,发短消息,或邮件konggu168@sohu.com
发表于 2008-4-4 18:03 | 显示全部楼层
  1. /* vsrk4.c: Fourth-order Runge-kutta method with variable step. */
  2. #define N 100
  3. #include "vsrk4.c"
  4. double f( double x, double y );
  5. extern int vsrk4( double hm[2], double x01[2],
  6.                  double x[N], double y[N], double eps);
  7. void main( )
  8. {
  9. int i,k;
  10. static double y0,eps,x01[2],hm[2],x[N],y[N];
  11. eps=1.0e-8;
  12. x01[0]=0.0;     /* x01[0]=a */
  13. x01[1]=1.0;     /* x01[1]=b */
  14. hm[0]=0.0005;   hm[1]=0.1;
  15. y0=1.0;         y[0]=y0;
  16. x[0]=x01[0];
  17. system("cls");
  18. printf("Variable step Fourth-order Runge-Kutta method:\n");
  19. k=vsrk4( hm, x01, x, y, eps );
  20. printf("     xn           yn\n");
  21. for(i=0;i<=k;i++)
  22.    printf("%12.8f %12.8f\n",x[i],y[i]);
  23. getch();
  24. }
  25. /********* function f( x, y ) ********/
  26. double f( double x, double y )
  27. {
  28. double f;
  29. f=y-2.0*x/y;
  30. return(f);
  31. }
  2. #include <stdio.h>
  3. #include <stdlib.h>
  4. #include <math.h>
  5. extern double f( double x, double y );
  6. double rk4( double x, double y, double hh );
  7. int vsrk4(double hm[2],double x01[2],double x[],double y[],double eps)
  8. {
  9. int i;
  10. double xx,h,hmax,hmin,x0,x1,yn,ynh,delta;
  11. hmin=hm[0]; hmax=hm[1];
  12. x0=x01[0];  x1=x01[1];
  13. h=hmax;
  14. xx=x0;
  15. i=0;
  16. x[0]=xx;
  17. while( xx < x1 )
  18.   {
  19. again:  if( xx+h > x1 ) h=x1-xx;
  20.   yn=rk4(xx,y[i],h);
  21.   ynh=rk4(xx,y[i],h/2.0);
  22.   ynh=rk4(xx+h/2.0,ynh,h/2.0);
  23.   delta=fabs((yn-ynh)/15.0);
  24.   if( ( delta < eps )||( h == hmin ) )
  25.     {
  26.     xx=xx+h;
  27.     i=i+1;
  28.     x[i]=xx;
  29.     y[i]=ynh;
  30.     if( i >= 99 ) goto endd;
  31.     if( delta < 0.05*eps )
  32.       {
  33.       h=2.0*h;
  34.       if( h > hmax ) h=hmax;
  35.       }
  36.     }
  37.   else
  38.     {
  39.     h=h/2.0;
  40.     if( h < hmin ) h=hmin;
  41.     goto again;
  42.     }
  43.   }
  44. endd:return(i);
  45. }
  46. /**************** fourth order Runge-Kutta *************************/
  47. double rk4( double xn, double yn, double h )
  48. {
  49. double ynp,k1,k2,k3,k4;
  50. k1=h*f(xn,yn);
  51. k2=h*f(xn+0.5*h,yn+0.5*k1);
  52. k3=h*f(xn+0.5*h,yn+0.5*k2);
  53. k4=h*f(xn+h,yn+k3);
  54. ynp=yn+(k1+2.0*k2+2.0*k3+k4)/6.0;
  55. return(ynp);
  56. }
发表于 2011-5-18 10:41 | 显示全部楼层
回复 3 # 风花雪月 的帖子
大侠,有变步长龙格库塔法的matlab程序吗?急求!不胜感激
发表于 2011-5-30 01:14 | 显示全部楼层
回复 4 # 煜宸0922 的帖子
Matlab还用编写RK程序吗?软件自带的ode45比起任何已经共享的C程序来说,精确多了,那可是一帮专门搞算法的大侠编写的供调用的function啊
发表于 2011-12-9 16:52 | 显示全部楼层
我也来蹭个程序学学。。。
发表于 2011-12-20 21:50 | 显示全部楼层
回复 3 # 风花雪月 的帖子
这个代码有误。。。
GMT+8, 2024-12-28 13:43 , Processed in 0.083930 second(s), 20 queries , Gzip On.
