查看: 1060|回复: 0
[综合讨论] SVPWM应用在整流器中的问题,求助!
发表于 2008-2-29 14:06 | 显示全部楼层 |阅读模式
我将本版置顶的SVPWM应用在整流器中时出现了:SVPWM仿真中扇区值N报警超出的错误。请大家帮忙解决一下,谢谢!
Out of bounds switch input specified for block 'kee_good_design26/pulse/tabcon/T12/Multiport Switch'.  The control input must be greater than or equal to 1 and less than or equal to the number of inputs if using one-based indexing; The control input must be greater than or equal to 0 and less than the number of inputs if using zero-based indexing
GMT+8, 2024-11-25 13:18 , Processed in 0.058508 second(s), 17 queries , Gzip On.
