查看: 1871|回复: 0
[其他软件] Vnoise算例-Advanced Muffler Tutorial
发表于 2008-1-31 18:12 | 显示全部楼层 |阅读模式
转自工程流体网
Index
Index..................................................................................................................2
Introduction ........................................................................................................3
Modelling considerations ......................................................................................3
TL Evaluation.......................................................................................................6
Overall procedure .................................................................................................6
Step 1: Model Import .............................................................................................7
Step 2: Intersections ...............................................................................................7
Step 3: Surface disconnection ................................................................................11
Step 5: Double wall ...............................................................................................15
Step 6: Inlet and Outlet...........................................................................................17
TL Calculation.......................................................................................................18
Pseudo Discretization ............................................................................................21
Symmetry .............................................................................................................22
Analysis.................................................................................................................23
TL Results ............................................................................................................24
Alternative procedure for TL evaluation...................................................................27
Sound radiated by the outlet.....................................................................................31
Coupled Analyses...................................................................................................36
Basic concepts ......................................................................................................36
Flexibility effect on TL ...........................................................................................38
Flexibility effect on external radiation ......................................................................44
Fully coupled approaches........................................................................................46
Fully coupled approach (Mixed Domain) .................................................................46
Introduction to Multi Domain ..................................................................................49
Fully coupled approach (Multi Domain)....................................................................51
Internal analysis with Multi Domains .......................................................................57
Flexibility effects on external radiation .....................................................................58
APPENDIX A ......................................................................................................64
Domain and Surface Types ....................................................................................64
Internal and External Surfaces ................................................................................64
Thin Shells..............................................................................................................64
Surfaces and calculation domain...............................................................................65
APPENDIX B........................................................................................................66
Mixed domain and multi Domain Comparison............................................................66
http://www.efluid.com.cn/images/ ... fler%20Tutorial.zip
GMT+8, 2025-1-13 07:36 , Processed in 0.057073 second(s), 17 queries , Gzip On.
