查看: 1514|回复: 3
[其他相关] 临界鞍点
发表于 2008-1-21 14:49 | 显示全部楼层 |阅读模式
临界鞍点应该是翻译为,critical node
有个外国编辑要我解释这个临界是什么意思,我该怎么解释,那位大哥英语好的,帮帮忙看看,谢谢
 楼主| 发表于 2008-1-24 10:27 | 显示全部楼层
回复 楼主 的帖子
是不是大家都过年去了,:lol
发表于 2008-1-27 15:44 | 显示全部楼层
Definition: (DOD) An element, position, or communications entity whose disruption or destruction immediately degrades the ability of a force to command, control, or effectively conduct combat operations.
http://usmilitary.about.com/od/glossarytermsc/g/criticalnode.htm
发表于 2008-1-27 15:45 | 显示全部楼层
An element, position, or command and control entity whose disruption or destruction immediately degrades the ability of a force to command, control, or effectively conduct combat operations. Also called target critical damage point.
http://www.thefreedictionary.com/critical+node
GMT+8, 2025-1-10 01:41 , Processed in 0.065083 second(s), 17 queries , Gzip On.
