查看: 1741|回复: 1
[综合讨论] Vnoise启动---HASP未找到
发表于 2008-1-18 17:39 | 显示全部楼层 |阅读模式
When I start VNoise I get the message "HASP not Found (-3)", what does it mean ?
When you get this message it means that your VNoise Dongle key (USB or parallel) is not properly inserted in the USB or parallel port.
If the key is correctly inserted and you still get the message there is a chance that the dongle drivers are not properly installed. Download the program for the drivers installation here included (hdd32.exe) and reinstall the drivers using the standard installation option.
If you should still have problems probably you dongle or you PC has some hardware problem, in this case please contact us at
support@sts-web.it, or through the web support.
发表于 2008-1-18 20:19 | 显示全部楼层
硬件加密狗?楼主在安装什么哪个版本?不是试用版吧?
GMT+8, 2025-1-28 10:45 , Processed in 0.115525 second(s), 17 queries , Gzip On.
