查看: 1823|回复: 1
[图像处理] avifile中可以不用compression吗
发表于 2008-1-15 22:46 | 显示全部楼层 |阅读模式
把帮助中avifile例程抄下来,也报错
fig=figure;
set(fig,'DoubleBuffer','on');
set(gca,'xlim',[-80 80],'ylim',[-80 80],...
    'NextPlot','replace','Visible','off')
mov = avifile('example.avi')
x = -pi:.1:pi;
radius = 0:length(x);
for k=1:length(x)
h = patch(sin(x)*radius(k),cos(x)*radius(k),...
    [abs(cos(x(k))) 0 0]);
set(h,'EraseMode','xor');
F = getframe(gca);
mov = addframe(mov,F);
mov = close(mov);
Can not locate Indeo5 compressor.  Compressor can be downloaded and installed from the Ligos web site.
我找不到这个解压补丁,想干脆不用解压,或Windows的解压,
用mov = avifile('example.avi','compression','MSVC');
或mov = avifile('example.avi','compression','None');
又都
??? Failed to open file.
Error in ==> avifile.avifile at 171
  aviobj.FileHandle = avi('open',filename);
请问我该怎么办,多谢
发表于 2008-1-16 13:43 | 显示全部楼层
先检查你的avi在你的系统里是否可以正常播放,应该是因为没有相应的解码器所致
GMT+8, 2025-1-28 05:19 , Processed in 0.076933 second(s), 17 queries , Gzip On.
