查看: 1399|回复: 0
[控制系统类] 大家帮我看看我写的LMS算法的S文件
发表于 2008-1-14 22:14 | 显示全部楼层 |阅读模式
刚学s函数,想拿这个来练手(我知道simulink中有这个模块),可是结果总是不对,大家帮我看看是那里不对啊,多谢了。
function [sys,x0,str,ts] = para(t,x,u,flag,w,r,mu,L)
L=64;
w(1:1:L)=0; %权向量
r(1:1:L)=0;%提取前L项输入用于计算
mu=1e-4; %步长
switch flag,
  % Initialization %
  case 0,
    [sys,x0,str,ts]=mdlInitializeSizes;
  % Derivatives %
  case 1,
    sys=mdlDerivatives(t,x,u);
  % Update %
  case 2,
    sys=mdlUpdate(t,x,u,w,r,mu,L);
  % Outputs %
  case 3,
    sys=mdlOutputs(t,x,u,w,r,mu,L);
  % GetTimeOfNextVarHit %
  case 4,
    sys=mdlGetTimeOfNextVarHit(t,x,u);
  % Terminate %
  case 9,
    sys=mdlTerminate(t,x,u);
  % Unexpected flags %
  otherwise
    error(['Unhandled flag = ',num2str(flag)]);
% end sfuntmpl
% mdlInitializeSizes
% Return the sizes, initial conditions, and sample times for the S-function.
function [sys,x0,str,ts]=mdlInitializeSizes
% call simsizes for a sizes structure, fill it in and convert it to a
% sizes array.
% Note that in this example, the values are hard coded.  This is not a
% recommended practice as the characteristics of the block are typically
% defined by the S-function parameters.
sizes = simsizes;
sizes.NumContStates  = 0;
sizes.NumDiscStates  = 2;  %第一个用于标记误差,第二个用于标记w值
sizes.NumOutputs     = 3;
sizes.NumInputs      = 2;
sizes.DirFeedthrough = 1;
sizes.NumSampleTimes = 1;   % at least one sample time is needed
sys = simsizes(sizes);
% initialize the initial conditions
x0  = [0 0 ];
% str is always an empty matrix
str = [];
% initialize the array of sample times
ts  = [0.001 0]; %采用时间0.001秒
% end mdlInitializeSizes
% mdlDerivatives
% Return the derivatives for the continuous states.
function sys=mdlDerivatives(t,x,u)
sys = [];
% end mdlDerivatives
% mdlUpdate
% Handle discrete state updates, sample time hits, and major time step
% requirements.
function sys=mdlUpdate(t,x,u,w,r,mu,L)
% sys(1)=u(1)-w*r';
% sys(2)=x(2)+2*mu*x(1)*u(1);
sys=[u(1)-w*r'; x(2)+2*mu*x(1)*u(1)];
% end mdlUpdate
% mdlOutputs
% Return the block outputs.
function sys=mdlOutputs(t,x,u,w,r,mu,L)
for i=1:1:L-1
    r(i)=r(i+1);
%     w(i)=w(i+1);
%     r(L)=u(1);
r(L)=u(1);
w=w+2*mu*x(1)*r;
sys(1)=w*r';
sys(2)=sqrt(w*w');
sys(3)=u(1)-sys(1);
% end mdlOutputs
% mdlGetTimeOfNextVarHit
% Return the time of the next hit for this block.  Note that the result is
% absolute time.  Note that this function is only used when you specify a
% variable discrete-time sample time [-2 0] in the sample time array in
% mdlInitializeSizes.
function sys=mdlGetTimeOfNextVarHit(t,x,u)
sampleTime = 1;    %  Example, set the next hit to be one second later.
sys = t + sampleTime;
% end mdlGetTimeOfNextVarHit
% mdlTerminate
% Perform any end of simulation tasks.
function sys=mdlTerminate(t,x,u)
sys = [];
% end mdlTerminate
GMT+8, 2025-2-20 11:50 , Processed in 0.092989 second(s), 17 queries , Gzip On.
