查看: 2660|回复: 2
请问这个错误该怎么办?
发表于 2008-1-8 12:10 | 显示全部楼层 |阅读模式
请问这个错误该怎么办?
Solver problem. Numerical singularity at D.O.F. 3 at one or more of the internal nodes of 40 elements. The elements have been identified in element set WarnElemSolvProbNumSing_3_0_0_0_0.
发表于 2008-1-8 15:02 | 显示全部楼层
40个单元的内部节点在3自由度上数值奇异(可能约束过多或没有约束)
 楼主| 发表于 2008-1-13 23:51 | 显示全部楼层
请问这又是什么问题呢?拜托了。
The elements in element set WarnElemFailElemInContact are part of a deformable surface that is referenced by a *CONTACT PAIR option in addition to having material properties that allow the element to fail. For elements that can fail, contact should be defined using the *CONTACT option.
GMT+8, 2025-1-17 23:06 , Processed in 0.067803 second(s), 17 queries , Gzip On.
