查看: 2876|回复: 9
错误讯息
发表于 2008-1-2 16:04 | 显示全部楼层 |阅读模式
"160 elements have missing property definitions. The elements have been identified in element set ErrElemMissingSection
Analysis Input File Processor exited with an error"
请问这个错误讯息是什么意思呢??
[ 本帖最后由 balflearlee 于 2008-1-2 16:37 编辑 ]
发表于 2008-1-2 17:27 | 显示全部楼层
"160个单元没有定义材料特性
这些单元被定义在ErrElemMissingSection集合中"
你可以装入odb文件,在element set里找到他们
 楼主| 发表于 2008-1-2 18:25 | 显示全部楼层
找到后又该怎么做呢?
发表于 2008-1-2 18:36 | 显示全部楼层
呵呵 在前处理中指定材料属性呀!
 楼主| 发表于 2008-1-3 11:19 | 显示全部楼层
请问这个错误讯息是什么意思呢??
P R O B L E M   S I Z E
          NUMBER OF ELEMENTS IS                                    10
          NUMBER OF NODES IS                                      128
          NUMBER OF NODES DEFINED BY THE USER                     128
          TOTAL NUMBER OF VARIABLES IN THE MODEL                  384
          (DEGREES OF FREEDOM PLUS ANY LAGRANGE MULTIPLIER VARIABLES)
                              END OF USER INPUT PROCESSING
     JOB TIME SUMMARY
       USER TIME (SEC)      =  0.10000
       SYSTEM TIME (SEC)    =   0.0000
       TOTAL CPU TIME (SEC) =  0.10000
       WALLCLOCK TIME (SEC) =          1
   Abaqus Version 6.7-1                                     DATE 03-Jan-2008   TIME 11:12:48
   For use by Team oDDiTy under license from ABAQUS, Inc.
      THREE LAYER COMPOSITE PLATE - SOLID ELEMENTS (CRD20R)                                    STEP    1  INCREMENT    1
        TIME COMPLETED IN THIS STEP   0.00
                        S T E P       1     S T A T I C   A N A L Y S I S
     AUTOMATIC TIME CONTROL WITH -
          A SUGGESTED INITIAL TIME INCREMENT OF                 1.00
          AND A TOTAL TIME PERIOD OF                            1.00
          THE MINIMUM TIME INCREMENT ALLOWED IS                1.000E-05
          THE MAXIMUM TIME INCREMENT ALLOWED IS                 1.00
     LINEAR EQUATION SOLVER TYPE         DIRECT SPARSE
STEP     1, INCREMENT          1, TIME INCREMENT=         0.100E+01, TOTAL TIME=         0.100E+01
REORDERING OF EQUATIONS TO MINIMIZE WAVEFRONT HAS CHANGED THE MEMORY AND DISK ESTIMATES TO:
                   M E M O R Y   A N D   D I S K   E S T I M A T E
           SUMMARY FOR CURRENT NODE ORDERING
          (NOTE THAT IF NODE ORDERING CHANGES THE SIZE ESTIMATES FOR THE STEPS WILL CHANGE)
           STEP   MAXIMUM DOF     FLOATING PT    MINIMUM MEMORY      MEMORY TO      REQUIRED DISKSPACE
                  WAVEFRONT       OPERATIONS       REQUIRED        MINIMIZE I/O
                                PER ITERATION     (MBYTES)           (MBYTES)          (KBYTES)
             1          72        8.62E+005          3.78               4.57            287.72
           MAX          72        8.62E+005          3.78               4.57            287.72
          THE TABLE ABOVE PROVIDES A STEP BY STEP SUMMARY OF SOME BASIC SIZING INFORMATION
          FOR THE PROBLEM. SOME FURTHER DESCRIPTION OF THE PARAMETERS GIVEN FOLLOWS:
          (1) MAXIMUM DOF WAVEFRONT - SIZE OF THE BIGGEST FRONT IN THE EQUATION SOLVER.
              PROVIDES A BASIC SIZING OF THE MOST MEMORY INTENSIVE SEGMENT OF SOLVER.
          (2) FLOATING POINT OPERATIONS PER ITERATION - MEASURE OF THE NUMBER OF FLOATING
              POINT OPERATIONS REQUIRED FOR A SINGLE SOLVER PASS. ON A GIVEN PLATFORM
              THE TIME REQUIRED FOR A SOLVER PASS WILL BE ROUGHLY A LINEAR FUNCTION
              OF THIS VALUE.
              NOTE - EXCEPT FOR THE FIRST STEP, THE VALUE IN THIS TABLE DOES NOT INCLUDE
                     ADDITIONAL FLOATING POINT OPERATIONS THAT ARE REQUIRED IN MULTIPLE LOAD
                     CASE STEPS WHEN CONSTRAINTS CHANGE FROM LOAD CASE TO LOAD CASE.  THIS
                     SITUATION CAUSES A REORDERING TO BE PERFORMED, AT WHICH TIME AN UPPER
                     BOUND ON THE NUMBER OF ADDITIONAL FLOATING POINT OPERATIONS WILL BE
                     CALCULATED AND INCLUDED UNDER THE ESTIMATE SUMMARIES FOR THE RELEVANT
                     STEPS (SEE NOTE BELOW ON REORDERING).
          (3) MINIMUM MEMORY REQUIRED - MINIMUM POSSIBLE MEMORY VALUE FOR standard_memory
              THAT ENABLES Abaqus TO SOLVE THE PROBLEM. USE OF MEMORY WILL BE MINIMIZED BY
              WRITING AS MUCH INFORMATION AS POSSIBLE TO DISK WHICH WILL INCREASE I/O TIME.
          (4) MEMORY TO MINIMIZE I/O - VALUE OF standard_memory THAT ALLOWS Abaqus TO KEEP
              ALL SIGNIFICANT SCRATCH FILES IN MEMORY. THIS WILL MINIMIZE I/O TIME FOR THE USER
              WITH ACCESS TO A LARGE AMOUNT OF MEMORY.
          (5) REQUIRED DISKSPACE - AMOUNT OF DISK REQUIRED FOR SCRATCH FILES. THESE WILL BE
              DELETED AT THE END OF THE ANALYSIS.
           NOTE - WHENEVER POSSIBLE THE USER SHOULD SET standard_memory TO BE LESS THAN THE
          PHYSICAL MEMORY ON THE MACHINE. UNLESS NECESSARY USERS SHOULD NOT MAKE USE
          OF VIRTUAL MEMORY EVEN IN AN ATTEMPT TO KEEP SCRATCH FILES IN MEMORY.
           NOTE - IF A REORDERING IS PERFORMED (THIS WILL ONLY GENERALLY BE DONE FOR FINITE-
          SLIDING CONTACT PROBLEMS), THE SIZE ESTIMATES DONE AT THIS TIME WILL NO LONGER
          BE VALID. THE ESTIMATES WILL BE REDONE IN THE EVENT OF A REORDERING AND A NEW
          SUMMARY WILL BE PRINTED FOR THE REMAINING STEPS.
           S I Z E   E S T I M A T E S   F O R   C U R R E N T   S T E P
          NUMBER OF EQUATIONS                        384
          MAX DOF WAVEFRONT                          72
          FLOATING POINT OPS PER SOLVER ITERATION   8.62E+005
          MEMORY USED FOR STEP                     256.00 MBYTES
           ESTIMATED FILE SIZES
           FILE           KWORDS           KBYTES
          .fct            17.328          135.375
          .nck             0.600            4.688
          .opr            18.900          147.656
           TOTAL          36.828          287.719
          THE ANALYSIS IS ENDED BECAUSE OF THE PROBLEMS ENCOUNTERED
          LOOK AT THE MSG FILE FOR THE CAUSE OF THE TERMINATION
                              ANALYSIS COMPLETE
                              WITH     1 ERROR MESSAGES ON THE MSG FILE
发表于 2008-1-3 17:26 | 显示全部楼层
使用D版abaqus的证据呀
“use by Team oDDiTy under license from ABAQUS, Inc.”
内存有问题!
计算量很大吗?干嘛用SOLID ELEMENTS?
 楼主| 发表于 2008-1-3 17:46 | 显示全部楼层
这是软件内附的例子啊,不过运算时有问题,真是内存问题啊,还以为了解错误。
没错,我是用D版:@L
发表于 2008-1-3 18:09 | 显示全部楼层
看来不只是中国有问题呀!malaysia的同志也喜欢用D版,看来正版化是没希望了。。。
看看msg
 楼主| 发表于 2008-1-3 19:39 | 显示全部楼层
我的D版还不是从中国网下载的。哈哈。:lol
这是个人心态问题,与国家地域无关吧。
发表于 2008-1-4 11:32 | 显示全部楼层
有一部分单元你在材料属性里没有定义,你可以先看一看模型,然后检查一下材料属性
GMT+8, 2025-1-17 23:10 , Processed in 0.090245 second(s), 17 queries , Gzip On.
