查看: 2615|回复: 12
[1stopt] 初次接触lsopt,有个问题想请教~~
发表于 2007-12-20 19:06 | 显示全部楼层 |阅读模式
请问如何在一张图上拟合多组数据,生成多条曲线~~
望赐教~~
 楼主| 发表于 2007-12-20 20:01 | 显示全部楼层
救命啊~~
发表于 2007-12-20 20:33 | 显示全部楼层
不是很明白你想做什么?每组单独拟合,再画到一张图上?
 楼主| 发表于 2007-12-21 14:28 | 显示全部楼层
对的,每组单独拟合后,如何画到一张图上呢?? 敬请赐教啊~~
 楼主| 发表于 2007-12-21 14:56 | 显示全部楼层
还有一个问题:
Title "指数方程拟合";
Parameters a,b,n;
Variable x1,,x2,y;
Function 0.0625*x2=(a+b*y^n)*(x1-(x2/6.25-1)/0.0039085);
  Data;
  x1,x2,y=
19.95        0.104996312        105.2891
19.86        0.103120543        105.3013
19.86        0.094333711        94.15575
19.86        0.093701861        94.96867
19.81        0.09480075        94.8097
19.85        0.093514995        94.28034
19.95        0.096044433        93.74751
19.85        0.094145547        94.08488
19.8        0.093210409        93.8884
19.87        0.094522257        93.84563
19.75        0.083914002        84.759
19.76        0.084701613        84.06706
19.86        0.085772191        84.03028
19.8        0.083516934        84.18983
19.79        0.083965555        84.14978
19.86        0.084520333        84.42152
19.82        0.076225812        75.89017
19.85        0.076122184        76.13325
19.97        0.07795811        75.9683
19.9        0.0785319        76.14096
19.79        0.077968027        76.31337
19.77        0.077658745        76.69019
19.79        0.077398968        76.68275
19.81        0.078278544        76.16989
19.84        0.077601285        77.87096
19.89        0.078376024        77.2194
19.95        0.079315957        77.21278
19.92        0.078844586        77.2692
19.92        0.069631933        69.91034
20        0.071263046        69.96062
19.9        0.071986201        71.21204
19.79        0.06890746        71.43196
19.95        0.071649758        71.86926
19.78        0.069274448        71.49632
19.78        0.069781756        70.9106
19.81        0.06968784        71.23213
19.95        0.071649758        70.82187
19.84        0.070103691        72.0444
19.86        0.070382298        71.33606
19.94        0.070987831        71.26257
19.95        0.070611615        71.15469
19.95        0.070611615        71.93015
20.04        0.071830414        70.90833
19.9        0.069864106        71.5128
20.04        0.071882853        71.42757
20.03        0.058920443        60.78783
19.97        0.057800142        59.97723
20.04        0.059926292        59.97535
20.12        0.059978725        60.19948
20.07        0.060283        60.51313
20.2        0.047320188        47.51841
20.11        0.047161927        47.30892
20.2        0.049387757        47.78242
20.14        0.048450528        47.44885
20.1        0.047068747        47.8866
20.2        0.04902864        47.77147
20.2        0.04902864        48.13955
20.17        0.048419346        47.65761
20.14        0.048450528        47.50145
为什么点运行程序,却没有反应呢~~,麻烦指教一下啊~~
发表于 2007-12-21 22:53 | 显示全部楼层
Variable x1,,x2,y;
上式x1和x2之间多了一个逗号
发表于 2007-12-21 23:33 | 显示全部楼层
把代码改为如下:
Title "指数方程拟合";
Parameters a,b,n;
Variable x1,x2,y;
Function y=((0.0625*x2/(x1-(x2/6.25-1)/0.0039085)-a)/b)^(1/n);
Data;
//  x1,x2,y=
结果:
均方差(RMSE): 1.22352320985848
残差平方和(SSE): 88.3235336586814
相关系数(R): 0.996661621183661
相关系数之平方(R^2): 0.993334387140444
决定系数(DC): 0.993334387071165
卡方系数(Chi-Square): 0.61320187275968
F统计(F-Statistic): 4200.66395977955
参数 最佳估算
a           2.65237163291613E-7
b           1.98988807456563E-7
n           1.02932035387151
 楼主| 发表于 2007-12-22 11:04 | 显示全部楼层
那这个图不是仅显示了y与其中一个自变量的关系啊,看不出来,它如何显示了y与x1和x2之间的关系啊??
 楼主| 发表于 2007-12-23 13:47 | 显示全部楼层
求救中~~~
 楼主| 发表于 2007-12-23 14:52 | 显示全部楼层
dingda,帮帮我啊,求你了啊,:@( ,我急用~~
朋友们,帮帮我啊~~急~~:@(
 楼主| 发表于 2007-12-23 15:48 | 显示全部楼层
问题一:
原帖由 ntzcx2007 于 2007-12-22 11:04 发表
问题二:
    每组数据单独拟合后,如何画到一张图上呢??
请指教啊,急,急,急~~
拜托各位大哥大姐了啊~~~
GMT+8, 2024-12-29 02:59 , Processed in 0.066882 second(s), 21 queries , Gzip On.
