查看: 1473|回复: 6
[HHT] 请问这个函数去哪里找?
发表于 2007-12-18 21:33 | 显示全部楼层 |阅读模式
hilbtmf()
发表于 2007-12-18 21:40 | 显示全部楼层
回复 #1 mzy 的帖子
这是什么函数,什么功能,完成哪方面的运算?
 楼主| 发表于 2007-12-18 22:36 | 显示全部楼层
我还以为大家都明白
rc-hw-0002 的程序中的,好像是hilbert()的改进
在别人的基础上改了一下:
function [S,freq] = HHTspe(imf,N,fs);
%%N--------分辨率
%fs-------采样频率
%s--------时间-频率-幅值矩阵
if(nargin<3)
    fs=1;
L = size(imf,1);
S = [];
clear x z m p freq
x = imf';
z = hilbtmf(x); % 用改进的Hilbert变换,效果好一些。
m = abs(z);
p = angle(z);
for i = 1:L
      freq(:,i) = instfreq(z(:,i))*fs; %乘以了采样频率
                  ceilfreq(:,i) = ceil(freq(:,i)*N);
            for j = 1:length(x)-2
            S(ceilfreq(j,i),j+1) = m(j+1,i);
%plot S
figure;
t=(1:length(x))/fs;
f=(1:size(S,1))/N; %
imagesc(t,f,S);
colorbar;
set(gca,'YDir','normal');
xlabel('Time t/s');
ylabel(' Frequency/HZ');
return
[ 本帖最后由 mzy 于 2007-12-18 22:37 编辑 ]
发表于 2007-12-18 22:39 | 显示全部楼层
这个吧
hilbtmf.m
6.06 KB, 下载次数: 33
发表于 2007-12-18 22:47 | 显示全部楼层
这个函数是哪里的?时频工具箱??
发表于 2007-12-18 22:50 | 显示全部楼层
这个
function h=hilbtmf(x)
%   h=hilbtmf(x):
%    Function to perform an improved Hilbert transform on data x(n,k),
%    where n specifies the length of time series, and
%    k - the number of IMF components.
%    The end effect is eliminated by extension of data by the wave,
%    which is calculated from the data points found between two extrema
%    across the zero crossing.
%    If the wave is not found (as in residue) the data is not extended.
%    The function applies smoothing the input data before processing.
%    Input-
% x - 2-D matrix x(n,k) of IMF components
%    Output-
% h - 2-D matrix h(n,k) of improved Hilbert transform
%    Z. Shen (JHU)  Jan. 1996   Initial
%    D. XIANG (JHU)  April 4, 2002 Modified
% (Extended both ends with 2 waves ending at zero crossing,
%        and both ends with the same slope.)
%    D. Xiang (JHU)  May 18, 2002 Modified
% (Added smoothing to overcome step function problem.
%        Added handling of the no wave situation.)
%    J.Marshak(NASA GSFC) Jan.16, 2004 Modified and edited
% (Replaced 'break' with 'continue' if no wave is found.)
%    Temporary remarks -
% The procedure stops if no wave is found for the IMF:
%       the IMFs that follow will not be processed and return the
% original data. It is the assumption that only one IMF
% (the last one) can have no detectable extrema (is the residue).
%       The suggestion is to use 'continue' instead of 'break' in order
% to pass the control to the next available IMF component or
% stop if there are none.
%----- Get dimensions
[n,kpt]=size(x);
%----- Use smoothing of x for n_mx and n_mn search
xx=zeros(n,kpt);
filtr=fir1(8,.1);
for j=1:kpt
   xx(:,j)=filtfilt(filtr,1,x(:,j));
%----- Process each IMF component
for j=1:kpt
    %-------------------Treat the head ----------------------------------
    indx1=0; indx2=0;
    n_mx=-1;
    n_mn=-1;
    j2=2;
    while j2<=n-1 ,
        if (xx(j2-1,j)<xx(j2,j))&(xx(j2,j)>=xx(j2+1,j)) % max point
            n_mx=j2;
            x_mx=xx(j2,j);
            indx1=1;
        elseif (xx(j2-1,j)>xx(j2,j))&(xx(j2,j)<=xx(j2+1,j)) % min point
            n_mn=j2;
            x_mn=xx(j2,j);
            indx2=1;
        if indx1>=.9 & indx2>=.9
            break
        j2=j2+1;
    if (n_mx==-1) | (n_mn==-1)
        %----- Do Hilbert transform directly if no max or min
        x(:,j)=hilbert(x(:,j));
        continue;
    elseif n_mn<n_mx,
zz=x(n_mn:n_mx,j);
mm1=size(zz);mm=mm1(1);
ia=fix(n_mn/(2*(mm-1)))+1;
iaa=max(ia,2); %DX, modify constant from 1 to 2.
zz1=flipud(zz);
x1=zz1;
for jj=1:iaa,
   x1=[x1;zz(2:mm);zz1(2:mm)];
        %----- Find the first zero-crossing and the slope -DX
        [r,c]=size(x1);
        for kk=1:r-1
          if((x1(kk)*x1(kk+1))<=0)
            if(abs(x1(kk)) > abs(x1(kk+1)))
               n0=kk;
            else
               n0=kk+1;
            s0=x1(kk+1)-x1(kk);
            break;
        x1=x1(n0:r);
        x1=[x1;x(n_mn+1:n,j)];
sz=max(size(x1));
np1=sz-n;
    else
zz=x(n_mx:n_mn,j);
        ia=fix(n_mx/(2*(mm-1)))+1;
zz1=flipud(zz);
        x1=[zz;zz1(2:mm)];
for jj=1:iaa,
        [r,c]=size(x1);
        for kk=1:r-1
                  n0=kk;
               else
                  n0=kk+1;
               s0=x1(kk+1)-x1(kk);
               break;
        x1=x1(n0:r);
x1=[x1;x(n_mx+1:n,j)];
sz=max(size(x1));
np1=sz-n;
    %---------------------Treat the tail----------------------------
    j2=n-1;
    indx1=0; indx2=0;
    while j2>=2 ,
            n_mx=j2;
            x_mx=xx(j2,j);
            indx1=1;
        elseif (xx(j2-1,j)>=xx(j2,j))&(xx(j2,j)<xx(j2+1,j)) % min point
            n_mn=j2;
            x_mn=xx(j2,j);
            indx2=1;
            break
        j2=j2-1;
    n_mn=n_mn+np1;
    n_mx=n_mx+np1;
    if n_mn<n_mx,
zz=x1(n_mn:n_mx);
mm=max(size(zz));
zz1=flipud(zz);
ia=fix((sz-n_mx)/(2*(mm-1)))+1;
iaa1=iaa*2;
x1=[x1(1:n_mx);zz1(2:mm)];
for jj=1:iaa
        x1=[x1;zz(2:mm-1)];
        [r,c]=size(x1);
        for k=1:r-1
           kk=r-k+1;
           if((x1(kk)*x1(kk-1))<=0)
           if(abs(x1(kk)) > abs(x1(kk-1)))
               n0=kk;
           else
               n0=kk-1;
           if(((x1(kk)-x1(kk-1))*s0)>0)   %same sign as s0
               break;
      x1=x1(1:n0);
    else
zz=x1(n_mx:n_mn);
mm=max(size(zz));
zz1=flipud(zz);
ia=fix((sz-n_mn)/(2*(mm-1)))+1;
iaa1=iaa*2;
x1=x1(1:n_mn);
for jj=1:iaa
     x1=[x1;zz1(2:mm);zz(2:mm)];
        x1=[x1;zz1(2:mm-1)];
        [r,c]=size(x1);
        for k=1:r-1
            kk=r-k+1;
                  n0=kk;
               else
                  n0=kk-1;
                  break;
        x1=x1(1:n0);
    %----- Apply Hilbert transform to the extended data
    x1=hilbert(x1);
    %----- Cut the extended portion
    x(:,j)=x1(np1:np1+n-1);
%----- Assign the output
h=x;
clear x
[ 本帖最后由 zhangnan3509 于 2007-12-19 08:53 编辑 ]
 楼主| 发表于 2007-12-19 20:03 | 显示全部楼层
谢谢大家
谢谢
GMT+8, 2025-1-12 00:56 , Processed in 0.075486 second(s), 22 queries , Gzip On.
