查看: 1663|回复: 2
[Fortran] 问一个关于if语句的问题
发表于 2007-12-12 21:45 | 显示全部楼层 |阅读模式
subroutine ghmatec(x,y,xm,ym,g,h,fi,dfi,kode,nx)
dimension g(nx,nx),h(nx,nx)
dimension x(1),y(1),xm(1),ym(1),fi(1),kode(1),dfi(1)
common n,l,nc(5),m,ge,xnu,inp,ipr
x(n+1)=x(1)
y(n+1)=y(1)
do 10 i=1,n
xm(i)=(x(i)+x(i+1))/2
10 ym(i)=(y(i)+y(i+1))/2
if (m-1) 15,15,12
12 xm(nc(1))=(x(nc(1))+x(1))/2
      ym(nc(1))=(y(nc(1))+y(1))/2
do 13 k=2,m
xm(nc(K))=(x(nc(k))+x(nc(k-1)+1))/2
13 ym(nc(K))=(y(nc(k))+y(nc(k-1)+1))/2
15 do 30 i=1,n
do 30 j=1,n
if(m-1) 16,16,17
17   if(j-nc(1))19,18,19
18   kk=1
      go to 23
19   do 22 k=2,m
      if (j-nc(k)) 22,21,22
21 kk=nc(k-1)+1
      go to 23
22    continue
16    kk=j+1
23    if(i-j) 20,25,20
20    call extinec(xm(i),ym(i),x(j),y(j),x(kk),y(kk),h((2*i-1),(2*j-1)),
     *h((2*i-1),(2*j)),h((2*i),(2*j-1)),h((2*i),(2*j)),g((2*i-1),(2*j-1)
     *),g((2*i-1),(2*j)),g((2*i),(2*j)))
g((2*i),(2*j-1))=g((2*i-1),(2*j))
go to 26
25    call locinec(x(j),y(j),x(kk),y(kk),g((2*i-1),(2*j-1)),
     *g((2*i-1),(2*j)),g((2*i),(2*j)))
  h((2*i-1),(2*j-1))=0.5
h((2*i),(2*j))=0.5
h((2*i-1),(2*j))=0
h((2*i),(2*j-1))=0
26 continue
30    continue
      nn=2*n
do 50 j=1,nn
if (kode(j))43,43,40
40    do 42 i=1,nn
      ch=g(i,j)
g(i,j)=-h(i,j)
42    h(i,j)=-ch
      go to 50
43    do 45 i=1,nn
45    g(i,j)=g(i,j)*ge
50    continue
      do 60 i=1,nn
dfi(i)=0
do 60 j=1,nn
dfi(i)=dfi(i)+h(i,j)*fi(j)
60    continue
      return
虽然,程序较长,那只是为了完整.
我只是想问下,红色的部分, if (m-1) 15,15,12 是什么意思?
是不是m-1为真,转到15?
后面3个数字不懂什么意思...
发表于 2007-12-12 21:55 | 显示全部楼层
看这段帮助
IF -- Arithmetic
Statement: Conditionally transfers control to one of three statements, based on the value of an arithmetic expression. It is an obsolescent feature in Fortran 95 and Fortran 90.
Syntax
IF (expr) label1, label2, label3
expr
Is a scalar numeric expression of type integer or real (enclosed in parentheses).
Are the labels of valid branch target statements that are in the same scoping unit as the arithmetic IF statement.
例如:
The following example transfers control to statement 50 if the real variable THETA is less than or equal to the real variable CHI. Control passes to statement 100 only if THETA is greater than CHI.
  IF (THETA-CHI) 50,50,100
意思是,如果THETA小于或等于实变量CHI,则转至statement 50,而只有THETA大于CHI的时候,转至statement 100
再如:The following statement transfers control to statement 10 for n < 10, to statement 20 for n = 10, and to statement 30 for n > 10:
  IF (n-10) 10, 20, 30
意思是:n<10时,转至statement 10,n=10时,转至statement 20,而当n>10时,转至statement 30
 楼主| 发表于 2007-12-12 22:04 | 显示全部楼层
回复 #2 octopussheng 的帖子
thank you very much
GMT+8, 2025-1-4 10:10 , Processed in 0.081175 second(s), 18 queries , Gzip On.
