查看: 2200|回复: 3
[Patran专区] 运行出错
发表于 2007-12-1 16:23 | 显示全部楼层 |阅读模式
各位大侠
运行patran的时候老师出现 Begin:Attach Result file
         就是不出现   End:Attach Result file
出错信息是:subcases select 时出来
For a multi-subcase Modal Transient Response analysis, errors will occur if subsequent subcases do not agree with the first subcase in the specification of ...          1) Boundary displacement constraints.          2) Frequency-dependent modal damping table.          3) Schedule of solution time increments.
那个地方有错呀!
谢谢
 楼主| 发表于 2007-12-1 20:14 | 显示全部楼层
那个地方要注意呀,结果出错
 楼主| 发表于 2007-12-4 22:21 | 显示全部楼层
应该是subcases select 中出错
谢谢
发表于 2007-12-27 15:48 | 显示全部楼层
这样的问题我也经常遇到
不知道是那里出问题了
GMT+8, 2025-1-4 14:55 , Processed in 0.065105 second(s), 17 queries , Gzip On.
