查看: 1250|回复: 2
[控制系统类] 永磁同步电机simulink仿真
发表于 2007-11-30 16:26 | 显示全部楼层 |阅读模式
在做时出现了---warning:Matching "Goto" block for "From" block 'he/Permanent Magnet Synchronous Mach----请问是哪里除了错误
发表于 2007-11-30 16:32 | 显示全部楼层
回复 #1 616hail 的帖子
好象是"Goto" block和"From" block 匹配有问题,楼主把问题没粘贴完啊,还是把完整的问题发上来看看吧.呵呵
 楼主| 发表于 2007-11-30 17:44 | 显示全部楼层
这就是全部的了,两个waining
Warning: Matching "Goto" block for "From" block 'he/Permanent Magnet Synchronous Machine/From' not found.
Warning: Matching "From" block for "Goto" block 'he/Permanent Magnet Synchronous Machine/Goto' not found.
GMT+8, 2024-11-25 13:19 , Processed in 0.065867 second(s), 19 queries , Gzip On.
