查看: 6114|回复: 5
求助:计算过程中的问题
发表于 2007-11-30 09:00 | 显示全部楼层 |阅读模式
我在做一个接触分析时遇到的,在几个小时的分析后(已成功进行一步迭代)提示出错.在查看msg文件后发现如下信息,要求我设定aba_scale_std_contact_connectivity到1.5618,但在abaqus_v6.env及release_abaqus_v6.env文件中均无此项,想请教在何处可以找到此项.
***WARNING: THE SYSTEM MATRIX HAS 18 NEGATIVE EIGENVALUES.
             EXPLANATIONS ARE SUGGESTED AFTER THE FIRST OCCURRENCE OF THIS MESSAGE.
***ERROR: THE MEMORY ALLOCATED TO PROCESS CONSTRAINT IS NOT ADEQUATE. SET THE
           ENVIRONMENT VARIABLE ABA_SCALE_STD_CONTACT_CONNECTIVITY TO A VALUE
           OF 1.5618 AND RERUN THE ANALYSIS.
[ 本帖最后由 zhangmeng 于 2007-12-3 14:31 编辑 ]
发表于 2007-12-2 18:12 | 显示全部楼层
老大,请仔细看英文提示
分配给此进程的内存不足
 楼主| 发表于 2007-12-3 10:03 | 显示全部楼层
呵呵,看到了.
不过后面的那句还是不明白
发表于 2007-12-3 12:43 | 显示全部楼层
abaqus job=job-name  [analysis | datacheck | parametercheck | continue |
                        convert={select | odb | state | all} | recover |
                        syntaxcheck | information={environment | local |
                        memory | release | support | system | all}]
                      [input=input-file]
                      [user={source-file | object-file}]
                      [oldjob=oldjob-name]
                      [fil={append | new}]
                      [globalmodel={results file-name |
                        output database file-name}]
                      [cpus=number-of-cpus]
                      [parallel={domain | loop]
                      [domains=number-of-domains]
                      [mp_mode={mpi | threads}]
                      [standard_parallel={all | solver}]
                      [memory=memory-size]
                      interactive | background | queue=[queue-name]
                        [after=time]
                      [double]
                      [scratch=scratch-dir]
                      [output_precision={single | full}]
                      [active_topology={off | on}]
                      [madymo=MADYMO-input-file]
                      [port=co-simulation port-number]
                      [host=co-simulation hostname]
                      [timeout=co-simulation timeout value in seconds]
 楼主| 发表于 2007-12-3 13:09 | 显示全部楼层
Thanks a lot!!!
发表于 2007-12-3 14:30 | 显示全部楼层
这不是接触的问题,应该是解算过程中的问题
GMT+8, 2025-1-21 12:29 , Processed in 0.098382 second(s), 17 queries , Gzip On.
