查看: 1638|回复: 1
[人工智能] 神经网络遗传算法
发表于 2007-11-26 01:14 | 显示全部楼层 |阅读模式
/*  神经网络遗传算法        */
|                  Robotics 95  --  Final Course Project                  |
|                    By :  Ziv Pollack  &  Omri Weisman                   |
|               NNUGA - Neural Network Using Genetic Algorithms           |
* File name : nnuga.c
* This program is an implementation of a Neural Network (NN) which learns u
sing
* Genetic Algorithms (GA). It runs from a Tk shell.
* It reads points from a file and creates an output file which describes
* points that correspond to lines that seperate the plain into several
* regions, regions where the NN's output will be true, and a regions
* where the NN's output will be false.
#include <stdio.h>
#include <math.h>
#include <sys/time.h>
/* NN related */
#define NUM 2         /* Number of input nodes */
#define LIMIT 150     /* Maximum number of inputs the system can handle */
#define SESSIONS 500  /* Number of training sessions that we'll put the syst
em through */
/* GA related */
#define POPS    10    /* Number of populations */
#define SIZE    25    /* Size of vector in the genetic algorithms */
#define MAXPOP  60    /* Size of population */
#define BESTPOP 4     /* Number of individuals taken from the best */
#define SELPOP  8     /* SELPOP-BESTPOP = Number of people selected randomly
on each gen. */
#define NEWPOP  18    /* NEWPOP-SELPOP = Number of new people, created rando
mly on each gen. */
#define MUT1    25    /* MUT1-NEWPOP = Number of mutations in the first muta
tion group */
#define MIXGEN  10    /* Number of generations between population mixing */
typedef struct
float p[NUM];
} vector;
/* NN related */
vector test[LIMIT], w1, w2, w3, w4, w5, w6;
int hits[LIMIT], total;
float w7[6];
int b1, b2, b3, b4, b5, b6, b7;
/* GA related */
float pop[POPS][MAXPOP][SIZE];
int score[POPS][MAXPOP];
|  Randomize                                                              |
randomize()
struct timeval tp;
struct timezone tzp;
/* Use time of day to feed the random number generator seed */
gettimeofday( &tp, &tzp);
srandom( tp.tv_sec );
|  irand( range )  - return a random integer in the range 0..(range-1)    |
int irand( range )
    int range;
return( random() % range );
|  scalar_mult - multiply two vectors                                     |
float scalar_mult( x, y ) vector x, y;
int i;
float s = 0.0;
for ( i = 0 ; i < NUM ; i++ )  s += ( x.p * y.p );
return s;
|  This function computes the NN's output for a certain input vector.     |
|  The NN is constructed from 2 layers, first layer has 6 neurons,        |
|  second layer has 1 neuron.                                             |
int net( x ) vector x;
/* First layer */
float a1 = atanpi( scalar_mult( w1, x ) + b1 ) / 1.6;  /* atan transfer fu
nction */
float a2 = atanpi( scalar_mult( w2, x ) + b2 ) / 1.6;  /* atan transfer fu
nction */
int   a3 = ( scalar_mult( w3, x ) + b3 ) > 0;          /* hardlim transfer
function */
int   a4 = ( scalar_mult( w4, x ) + b4 ) > 0;          /* hardlim transfer
function */
float a5 = scalar_mult( w5, x ) + b5 ;                 /* linear transfer
function */
float a6 = scalar_mult( w6, x ) + b6 ;                 /* linear transfer
function */
/* Second layer */
float a7 = ( a1*w7[0] + a2*w7[1] + a3*w7[2] + a4*w7[3] +
              a5*w7[4] + a6*w7[5] + b7 ) > 0.0;         /* hardlim transfer
function */
return(a7);
|  pop_swap( p, a, b )  -  swap two vectors and scores in the population p|
pop_swap( p, a, b )
    int p, a, b;
int t, i;
/* Swap vector */
for ( i = 0 ; i < SIZE ; i++ )
     t = pop[p][a];
     pop[p][a] = pop[p];
     pop[p] = t;
/* Swap score */
t = score[p][a];
score[p][a] = score[p];
score[p] = t;
|  apply( p, i ) -  apply the i vector of the population p on the NN      |
apply( p, i )
    int p, i;
/* Get the weights and biases of the neurons from the GA vector */
w1.p[0] = pop[p][0];  w1.p[1] = pop[p][1];  b1 = pop[p][2];
w2.p[0] = pop[p][3];  w2.p[1] = pop[p][4];  b2 = pop[p][5];
w3.p[0] = pop[p][6];  w3.p[1] = pop[p][7];  b3 = pop[p][8];
w4.p[0] = pop[p][9];  w4.p[1] = pop[p][10];  b4 = pop[p][11];
w5.p[0] = pop[p][12];  w5.p[1] = pop[p][13];  b5 = pop[p][14];
w6.p[0] = pop[p][15];  w6.p[1] = pop[p][16];  b6 = pop[p][17];
w7[0] = pop[p][18];
w7[1] = pop[p][19];
w7[2] = pop[p][20];
w7[3] = pop[p][21];
w7[4] = pop[p][22];
w7[5] = pop[p][23];
b7    = pop[p][24];
|  pop_copy( p1, a, p2, b ) - copy the vector b in the population p2 into |
|                             the vector a in the population p1.          |
pop_copy( p1, a, p2, b)
    int p1, a, p2, b;
int i;
   pop[p1][a] = pop[p2];
|  Initialize the populations                                             |
make_initial_population()
int p, i, j;
for ( p = 0 ; p < POPS ; p++ )
     /* Half population gets values from -1 to 1 */
     for ( i = 0 ; i < (MAXPOP/2) ; i++ )
       for ( j = 0 ; j < SIZE ; j++ )
         pop[p][j] = ((random()&1048575) / 1000000.0 - 0.5) * 2;
     /* Half population gets values from -100 to 100 */
     for ( i = (MAXPOP/2) ; i < MAXPOP ; i++ )
         pop[p][j] = ((random()&1048575) / 10000.0 - 50) * 2;
|   Calculate the scores of all the vectors in all the populations        |
calc_score()
int p, i;
   for ( i = 0 ; i < MAXPOP ; i++ )
       apply( p, i );
       score[p] = check_performance();
|   Sort the populations                                                  |
sort_population()
int p, i, j, k, best;
/* Use insert sort */
   for ( i = 0 ; i < (MAXPOP-1) ; i++ )
       best = score[p];
       for ( j = (i+1) ; j < MAXPOP ; j++ )
         if ( score[p][j] > best )
             best = score[p][j];
             k = j;
       if ( best > score[p] )
         pop_swap( p, i, k );
|   Show (on the standard output) the best scores of all populations      |
statistics( generation )
    int generation;
int p;
if ( generation % MIXGEN == 0 )
   printf("-----------------------------\n");
printf(" %4d) First are: ", generation);
for ( p = 0 ; p < POPS ; p++ )  printf("%3d ", score[p][0] );
printf(" (from %d)\n",total);
|  Generate the next generation in all populations                        |
make_next_generation( generation )
    int generation;
int p, i, j, k1, k2, m;
float dev;
     /* keep best - BESTPOP */
     /* add another group, randomly  - (SELPOP-BESTPOP) */
     for ( i = BESTPOP ; i < SELPOP ; i++ )
       pop_swap( p, i, (irand( MAXPOP - i ) + i) );
     /* create new individuals */
     for ( i = SELPOP ; i < NEWPOP ; i++ )
         pop[p][j] = ((random()&1048575) / 100000.0 - 5) * 2;
     /*  SELPOP to MUT1 will be severe mutations */
     for ( i = NEWPOP ; i < MUT1 ; i++ )
         pop_copy( p, i, p, irand(NEWPOP) );
         dev = 1 + ((irand(2000) - 1000 )/ 5000);
         pop[p][irand(SIZE)] *= dev;
     /* MUT2 to MAXPOP will be crossovers */
     for ( i = MUT1 ; i < MAXPOP ; i++ )
         /* Every several generations (set by MIXGEN) there is a cross-over
            between different populations. */
         pop_copy( p, i, (((generation%MIXGEN)==0) ? irand(POPS) : p), iran
d(NEWPOP) );
         j = irand(NEWPOP);
         k1 = irand( SIZE - 1);
         k2 = irand( SIZE - 1 - k1 ) + k1 + 1;
         for ( m = k1 ; m <= k2 ; m++ ) pop[p][m] = pop[p][j][m];
         /* Mutate slightly */
         dev = 1 + ((irand(2000) - 1000 )/ 50000);
calc_score();
sort_population();
statistics( generation );
|  Return the number of cases for which the NN returns the correct value  |
check_performance()
vector x;
int j, count=0;
for ( j = 0 ; j < total ; j++ )
     x = test[j];
     if ( net(x) == hits[j] )
       count++;
return count;
|  Get data (read input file)                                             |
int get_data()
char* FileName = "/tmp/nn-input";
FILE *fd;
int i, posnum, negnum;
float x,y;
/* opens the file  */
if ( (fd = fopen(FileName,"r")) == NULL )
     printf ("no-input-file");
     exit(10);
/* Total number of input values */
total = 0;
/* read the positive examples */
fscanf( fd, "%d", &posnum);
if (posnum > LIMIT)
     printf("Error");
     exit(20);
for ( i = 0 ; i < posnum ; i++ )
     fscanf( fd, "%f %f", &x, &y);
     test[ total ].p[0] = x / 1000;
     test[ total ].p[1] = y / 1000;
     hits[ total++ ] = 1;  /* 1 for positive examples */
/* read the negative examples */
fscanf( fd, "%d", &negnum);
if ((negnum+total) > LIMIT)
     printf("Error");
     exit(21);
for ( i = 0 ; i < negnum ; i++ )
     hits[ total++ ] = 0; /* 0 for negative example */
fclose( fd );
return (0) ;
|   best_pop  -  Find the population with the best solution               |
int best_pop()
int i, p, best = 0;
for ( i = 0 ; i < POPS ; i++ )
   if ( score[0] > best )
       best = score[0];
       p = i;
return(p);
|   charmap  -  draw a charmap showing the NN's behaviour                 |
charmap( p )
    int p;
int i, j, result;
vector x;
apply( p ,0 );
for ( i = 0 ; i < 350 ; i++ )
     for ( j = 0 ; j < 350 ; j++ )
       if ( (i%12==0) && (j%6==0) )
           x.p[0] = j/1000.0;
           x.p[1] = i/1000.0;
           result = net( x );
           printf("%c", (result==1 ? '+' : '.' ) );
     if ( i%12==0 ) printf("\n");
|   make_output  -  create the output file                                |
make_output(p)
    int p;
int i, j, result, oldresult, start;
vector x;
char* FileName = "/tmp/nn-output";
FILE *fd;
printf("\n%s\n", (score[p][0]!=total ? "Failed." : "Success" ) );
apply( p, 0 );
printf("Writing output file...\n");
/* Open the file  */
if ( (fd = fopen(FileName,"w")) == NULL )
     printf ("Can't open output file");
     exit(10);
/* line scheme */
for ( i = 0 ; i < 350 ; i++ )  /* Scan horizontally */
     result = 0;
         oldresult = result;
         x.p[0] = j/1000.0;
         x.p[1] = i/1000.0;
         result = net( x );
         if ( oldresult != result )
           fprintf( fd, "%d %d ", j, i );
for ( j = 0 ; j < 350 ; j++ )  /* Scan vertically */
     result = 0;
         oldresult = result;
         x.p[0] = j/1000.0;
         x.p[1] = i/1000.0;
         result = net( x );
fclose( fd );
printf("Done!\n");
|  Main        |
main()
int generation, j, p, best, done = 0;
float px, py, px1, py1;
randomize();
get_data();  /* Read input from file */
make_initial_population();
calc_score();
sort_population();
/* Educate the net */
generation = 0;
while ( (done != 1 ) && ( generation++ < SESSIONS ) )
     make_next_generation( generation );
     p = best_pop();
     /* Show a charmap every 50 generations */
     if ( generation % 50 == 0 ) charmap(p);
     if ( score[p][0] == total )
       done = 1;
/* return results */
make_output(p);
发表于 2007-11-26 11:11 | 显示全部楼层
好长!
GMT+8, 2025-1-4 11:14 , Processed in 0.088900 second(s), 22 queries , Gzip On.
