查看: 1769|回复: 1
[综合讨论] 取高斯积分点求积的精度有多高
发表于 2007-11-21 15:47 | 显示全部楼层 |阅读模式
如图:
光滑曲线由其他数值积分得到;(quadl)
另条曲线是取了8个高斯积分点。
%Gause积分点与权系数
root=[-0.9602898564975363,-0.7966664774136268,-0.525532409916329,-0.1834346424956498,0.1834346424956498,...
    0.525532409916329,0.7966664774136268,0.9602898564975363];
weight=[0.1012285362903768,0.2223810344533745,0.3137066458778874,0.362683783378362,0.362683783378362,...
    0.3137066458778874,0.2223810344533745,0.1012285362903768];
两者结果相差较大。
原因分析:
1。两种方法之1有错。
2。高斯积分点精度差.
愿高手指点。。。
[ 本帖最后由 eight 于 2007-11-21 16:55 编辑 ]
发表于 2007-11-22 11:06 | 显示全部楼层
数值积分的系列函数的精度可以设置,help里有
Q = QUADL(FUN,A,B,TOL) uses an absolute error tolerance of TOL
    instead of the default, which is 1.e-6.  Larger values of TOL
    result in fewer function evaluations and faster computation,
    but less accurate results.
GMT+8, 2025-1-14 18:13 , Processed in 0.091305 second(s), 23 queries , Gzip On.
