查看: 1647|回复: 2
[基本模块类] 力到速度之间的增益模块用质量的倒数?
发表于 2007-11-15 20:54 | 显示全部楼层 |阅读模式
老提示:Warning: Using a default value of 0.2 for maximum step size. The simulation step size will be limited to be less than this value.另外响应时间非常短,不知道什么原因俺是新手请多指教!
micro.mdl
18.35 KB, 下载次数: 3
 楼主| 发表于 2007-11-15 21:19 | 显示全部楼层
请各位帮忙看看出现的那个警告是什么原因,需要再加什么模块吗
 楼主| 发表于 2007-11-17 15:16 | 显示全部楼层
是solver选择的问题,改为fixed step出现
Warning: Unable to determine a fixed step size based on the sample times in the model 'micro', because the model does not have any discrete sample times.  Picking a fixed step size of (0.002) based on simulation start and stop times.  You can disable this diagnostic by explicitly specifying a fixed step size in the solver tab of the simulation parameters dialog, or setting 'Automatic solver parameter selection' diagnostic to 'none' in the Diagnostics tab of the configuration parameters dialog.
然后设置fixed step 为0.002后就没有警告了。
但是速度不是从零开始的,为什么呀。怎么样才可以让速度从零开始?
GMT+8, 2024-11-25 13:55 , Processed in 0.084566 second(s), 21 queries , Gzip On.
