查看: 1127|回复: 1
[控制系统类] 模糊控制中出现的问题
发表于 2007-11-15 17:10 | 显示全部楼层 |阅读模式
Warning: Unconnected input line found on 'test2/Fuzzy Logic  Controller/FIS Wizard/MuxOut' (input port: 1).
Warning: Unconnected line found in 'test2/Fuzzy Logic
Controller/FIS Wizard'.
这是怎么回事?
高手帮忙了,谢谢啦!!
 楼主| 发表于 2007-11-15 17:11 | 显示全部楼层
还有这个
Warning: Using a default value of 0.6 for maximum step size. The simulation step size will be limited to be less than this value.
GMT+8, 2024-11-25 12:41 , Processed in 0.075924 second(s), 18 queries , Gzip On.
