查看: 918|回复: 1
[编程技巧] newrbe这个命令是作啥用的呀?
发表于 2007-10-28 14:54 | 显示全部楼层 |阅读模式
哪位高人给我讲解一下呀
[ 本帖最后由 eight 于 2007-10-28 16:29 编辑 ]
发表于 2007-10-28 16:29 | 显示全部楼层
>> help newrbe
NEWRBE Design an exact radial basis network.
   Synopsis
     net = newrbe(P,T,SPREAD)
   Description
     Radial basis networks can be used to approximate functions.
     NEWRBE very quickly designs a radial basis network with
     zero error on the design vectors.
     NEWRBE(P,T,SPREAD) takes two or three arguments,
     P      - RxQ matrix of Q input vectors.
     T      - SxQ matrix of Q target class vectors.
     SPREAD - of radial basis functions, default = 1.0.
     and returns a new exact radial basis network.
     The larger that SPREAD, is the smoother the function approximation
     will be. Too large a spread can cause numerical problems.
   Examples
     Here we design a radial basis network, given inputs P
     and targets T.
       P = [1 2 3];
       T = [2.0 4.1 5.9];
       net = newrbe(P,T);
     Here the network is simulated for a new input.
       P = 1.5;
       Y = sim(net,P)
   Algorithm
     NEWRBE creates a two layer network. The first layer has RADBAS
     neurons, and calculates its weighted inputs with DIST, and its
     net input with NETPROD.  The second layer has PURELIN neurons,
     and calculates its weighted input with DOTPROD and its net inputs
     with NETSUM. Both layer's have biases.
     NEWRBE sets the first layer weights to P', and the first
     layer biases are all set to 0.8326/SPREAD, resulting in
     radial basis functions that cross 0.5 at weighted inputs
     of +/- SPREAD.
     The second layer weights IW{2,1} and biases b{2} are found by
     simulating the first layer outputs A{1}, and then solving the
     following linear expression:
         [W{2,1} b{2}] * [A{1}; ones] = T
   See also sim, newrb, newgrnn, newpnn.
    Reference page in Help browser
       doc newrbe
GMT+8, 2025-1-30 01:28 , Processed in 0.195932 second(s), 17 queries , Gzip On.
