查看: 3728|回复: 5
[Fluent应用] gambit无法打开
发表于 2007-10-15 21:52 | 显示全部楼层 |阅读模式
今天重装系统gambit打不开,提示不能找到exceed,建议打开gambit之前手动打开exceed,是什么原因,有人遇到过这样的问题么
发表于 2007-10-16 08:56 | 显示全部楼层
装exceed了吗?
 楼主| 发表于 2007-10-16 22:23 | 显示全部楼层
装了exceed2007,我装的64位操作系统,gambit是32位软件
 楼主| 发表于 2007-10-16 22:44 | 显示全部楼层
错误代码:
Locating Exceed installation ...
gambit failed in locating Exceed installation on your system.
Please try to start Exceed manually before you run gambit.
Starting C:\Fluent.Inc\gambit2.3.16\ntx86\gambit.exe -device open -id default_id2784 -new  ...
Gambit build SP2006032921.
Warning : The current transport does not permit the attempted TCPIP connection.
TRANS(SocketINETGetAddr): tnamebysocket() failed
TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed
TRANS(Open): transport open failed for tcp/boss:0
Unable to open display
发表于 2008-1-18 09:32 | 显示全部楼层
你可以直接装HUMMINGBIRD.EXCEED.POWERSUITE.V11,你就可以用了
发表于 2008-1-19 19:55 | 显示全部楼层
呵呵,学习了
GMT+8, 2024-11-25 18:51 , Processed in 0.052371 second(s), 17 queries , Gzip On.
