查看: 5312|回复: 17
[其他相关] matlab不能运行??
 关闭 [复制链接]
发表于 2007-10-11 12:08 | 显示全部楼层 |阅读模式
环境变量我改了,开始出现“找不到指定模块”,然后“找不到指定模块”,矩阵函数不能用,好像积分函数也不能用,其他的好像还能用。
打开matlab出现的东西:
  To get started, select MATLAB Help or Demos from the Help menu.
       Segmentation violation detected at Thu Oct 11 12:01:51 2007
Configuration:
  MATLAB Version:   7.0.0.19920 (R14)
  Operating System: Microsoft Windows XP
  Window System:    Version 5.1 (Build 2600: Service Pack 2)
  Processor ID:     x86 Family 15 Model 11 Stepping 2, AuthenticAMD
  Virtual Machine:  Java 1.4.2 with Sun Microsystems Inc. Java HotSpot(TM) Client VM
    (mixed mode)
  Default Charset:  ibm-1386_P100-2002
Register State:
  EAX = 00000000  EBX = 00000000
  ECX = 7c80996d  EDX = 00750001
  ESI = 0130a750  EDI = 014cf510
  EBP = 00cda6d8  ESP = 00cda648
  EIP = 00000000  FLG = 00010206
Stack Trace:
  [0] numerics.dll:??$mfGenMatrixMult@N@@YAXPAUmxArray_tag@@00W4MM_Transpose@@1N@Z(0x014cfbd0, 0x014cf510, 0x014cfc50, 0) + 532 bytes
  [1] numerics.dll:void __cdecl mfGenMatrixMult(struct mxArray_tag *,struct mxArray_tag *,struct mxArray_tag *,enum MM_Transpose,enum MM_Transpose)(0x014cfbd0, 0x014cf510, 0x014cfc50, 0) + 120 bytes
  [2] numerics.dll:void __cdecl mfTimesTransposeFcn2DFloatPt(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const)(0, 0x00cda88c, 6, 0x00cda7fc) + 913 bytes
  [3] m_dispatcher.dll:public: virtual void __thiscall Mfh_builtin<struct mxArray_tag>::dispatch_mf(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00cda88c, 3, 0x00cda7fc) + 55 bytes
  [4] m_dispatcher.dll:public: virtual void __thiscall Mfh_MATLAB_fn::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00cda88c, 3, 0x00cda7fc) + 200 bytes
  [5] m_interpreter.dll:void __cdecl inJitCallMatlabFunctionPtrNoDestroy(class Mfh_MATLAB_fn *,int,int,struct mxArray_tag * * const,int,struct mxArray_tag * * const)(0x01457d20, 322, 1, 0x00cda88c) + 89 bytes
  [6] m_interpreter.dll:int __cdecl accelExec(struct _accelBytecode *,enum inMarshalType *)(0x0130a730, 0x00cdaa64, 0, 0) + 16855 bytes
  [7] m_interpreter.dll:_inExecuteHotSegment(0x00cdaa98, 0x00cdab68, 0x00cdab18, 0) + 1542 bytes
  [8] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *)(1, 3667, 95, 0) + 365 bytes
  [9] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *)(1, 3667, 35, 0) + 272 bytes
  [10] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x106840b0, 0, 2, 2) + 773 bytes
  [11] m_interpreter.dll:_inWordsj(0, 0x00cdb5b8, 2, 0x00cdb648) + 441 bytes
  [12] m_interpreter.dll:public: void __thiscall Mfh_mp::inRunMP(int,struct mxArray_tag * *,int,struct mxArray_tag * *,struct inWorkSpace_tag *)(0, 0x00cdb5b8, 2, 0x00cdb648) + 158 bytes
  [13] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0, 0x00cdb5b8, 2) + 28 bytes
  [14] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00cdb5b8, 2, 0x00cdb648) + 26 bytes
  [15] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00cdb5b8, 2, 0x00cdb648) + 273 bytes
  [16] m_interpreter.dll:public: void __thiscall ResolverFunctionDesc::CallFunction(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const)(0, 0x00cdb5b8, 2, 0x00cdb648) + 246 bytes
  [17] m_interpreter.dll:public: bool __thiscall Resolver::CallMFunction(int,int,class _m_operand * const,union m_operand_storage *,int,class _m_operand * const,union m_operand_storage *,int *)(0, 1, 0x014bb050, 0) + 840 bytes
  [18] m_interpreter.dll:bool __cdecl inResolveMFunctionCall(struct _m_function_desc *,int,int,class _m_operand * const,union m_operand_storage *,int,class _m_operand * const,union m_operand_storage *,int *,enum inMarshalType *,unsigned int,int,unsigned int *,int)(0x10b036c0, 0, 1, 0x014bb050) + 148 bytes
  [19] m_interpreter.dll:bool __cdecl accelMFunctionCall(struct _accelOp *,struct _accelOp * *,struct _accelBytecode *,int *,enum inMarshalType *)(0x1071dca0, 0x00cdbc5c, 0x0130a0d0, 0x00cdbc54) + 108 bytes
  [20] m_interpreter.dll:int __cdecl accelExec(struct _accelBytecode *,enum inMarshalType *)(0x0130a0d0, 0x00cdbcd4, 0, 12) + 18462 bytes
  [21] m_interpreter.dll:_inExecuteHotSegment(0x00cdbd08, 0x00cdbd64, 0x00cdbd54, 0x00cdc758) + 1542 bytes
  [22] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x10737bf0, 0, 1, 1) + 610 bytes
  [23] m_interpreter.dll:_inWordsj(0, 0x00cdc6c8, 1, 0x00cdc758) + 441 bytes
  [24] m_interpreter.dll:public: void __thiscall Mfh_mp::inRunMP(int,struct mxArray_tag * *,int,struct mxArray_tag * *,struct inWorkSpace_tag *)(0, 0x00cdc6c8, 1, 0x00cdc758) + 158 bytes
  [25] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0, 0x00cdc6c8, 1) + 28 bytes
  [26] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00cdc6c8, 1, 0x00cdc758) + 26 bytes
  [27] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00cdc6c8, 1, 0x00cdc758) + 273 bytes
  [28] m_interpreter.dll:public: void __thiscall ResolverFunctionDesc::CallFunction(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const)(0, 0x00cdc6c8, 1, 0x00cdc758) + 246 bytes
  [29] m_interpreter.dll:public: bool __thiscall Resolver::CallMFunction(int,int,class _m_operand * const,union m_operand_storage *,int,class _m_operand * const,union m_operand_storage *,int *)(0, 1, 0x014cf350, 0) + 840 bytes
  [30] m_interpreter.dll:bool __cdecl inResolveMFunctionCall(struct _m_function_desc *,int,int,class _m_operand * const,union m_operand_storage *,int,class _m_operand * const,union m_operand_storage *,int *,enum inMarshalType *,unsigned int,int,unsigned int *,int)(0x10b03580, 0, 1, 0x014cf350) + 148 bytes
  [31] m_interpreter.dll:bool __cdecl accelMFunctionCall(struct _accelOp *,struct _accelOp * *,struct _accelBytecode *,int *,enum inMarshalType *)(0x106a5d10, 0x00cdcd6c, 0x0130a100, 0x00cdcd64) + 108 bytes
  [32] m_interpreter.dll:int __cdecl accelExec(struct _accelBytecode *,enum inMarshalType *)(0x0130a100, 0x00cdcde4, 0, 0) + 18462 bytes
  [33] m_interpreter.dll:_inExecuteHotSegment(0x00cdce18, 0x00cdcee8, 0x00cdce98, 0) + 1542 bytes
  [34] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *)(1, 425, 50, 0) + 365 bytes
  [35] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *)(1, 425, 31, 0) + 272 bytes
  [36] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x108a9250, 0, 2, 2) + 773 bytes
  [37] m_interpreter.dll:_inWordsj(0, 0x00cdd404, 2, 0x00cdd464) + 441 bytes
  [38] m_interpreter.dll:public: void __thiscall Mfh_mp::inRunMP(int,struct mxArray_tag * *,int,struct mxArray_tag * *,struct inWorkSpace_tag *)(0, 0x00cdd404, 2, 0x00cdd464) + 158 bytes
  [39] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0, 0x00cdd404, 2) + 28 bytes
  [40] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00cdd404, 2, 0x00cdd464) + 26 bytes
  [41] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00cdd404, 2, 0x00cdd464) + 273 bytes
  [42] m_interpreter.dll:_inDispatchFromStack(460, 0x015c176e "colordef", 0, 2) + 891 bytes
  [43] m_interpreter.dll:_inCallFcnFromReference(0, 0x00cddeac, 0x789b59c0, 0xcccccccd) + 176 bytes
  [44] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *)(1, 0, 59, 0) + 4115 bytes
  [45] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *)(1, 0, 16, 0) + 272 bytes
  [46] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x1069acd0, 1, 0, 0x1069acd0) + 773 bytes
  [47] m_interpreter.dll:_inExecCompScript(0, 0x00cddae4, 0x1069acd0, 0xffffffff) + 321 bytes
  [48] m_interpreter.dll:public: void __thiscall Mfh_mp::inRunMP(int,struct mxArray_tag * *,int,struct mxArray_tag * *,struct inWorkSpace_tag *)(0, 0x00cddae4, 0, 0x00cddb44) + 122 bytes
  [49] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0, 0x00cddae4, 0) + 28 bytes
  [50] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00cddae4, 0, 0x00cddb44) + 26 bytes
  [51] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00cddae4, 0, 0x00cddb44) + 273 bytes
  [52] m_interpreter.dll:_inDispatchFromStack(459, 0, 0, 0) + 891 bytes
  [53] m_interpreter.dll:_inCallFcnFromReference(0, 0x1062f800, 0x789b59c0, 0xcccccccd) + 176 bytes
  [54] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *)(1, 0, 89, 0) + 4115 bytes
  [55] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *)(1, 0, 18, 0) + 272 bytes
  [56] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x016635e0, 1, 0, 0x016635e0) + 773 bytes
  [57] m_interpreter.dll:_inExecCompScript(0, 0x00cde1c4, 0x016635e0, 0xffffffff) + 321 bytes
  [58] m_interpreter.dll:public: void __thiscall Mfh_mp::inRunMP(int,struct mxArray_tag * *,int,struct mxArray_tag * *,struct inWorkSpace_tag *)(0, 0x00cde1c4, 0, 0x00cde224) + 122 bytes
  [59] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0, 0x00cde1c4, 0) + 28 bytes
  [60] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00cde1c4, 0, 0x00cde224) + 26 bytes
  [61] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00cde1c4, 0, 0x00cde224) + 273 bytes
  [62] m_interpreter.dll:_inDispatchFromStack(450, 0x013f3424 "matlabrc", 0, 0) + 891 bytes
  [63] m_interpreter.dll:enum opcodes __cdecl inDispatchCall(char const *,int,int,int,int *,int *)(0x013f3424 "matlabrc", 450, 0, 0) + 111 bytes
  [64] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *)(0, 0, 0, 0) + 2411 bytes
  [65] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *)(0, 0, 0, 0) + 272 bytes
  [66] m_interpreter.dll:_inInterPcode(0, 0x7876f2d8, 0, 0) + 69 bytes
  [67] m_interpreter.dll:enum inExecutionStatus __cdecl in_local_call_eval_function(int *,struct _pcodeheader *,int *,struct mxArray_tag * * const,enum inDebugCheck)(0x00cded70, 0x00cdee64, 0, 0x79c71190 "matlabrc") + 162 bytes
  [68] m_interpreter.dll:$L72592(0x7876f2d8, 0x79c71190 "matlabrc", 8, 0) + 196 bytes
  [69] m_interpreter.dll:enum inExecutionStatus __cdecl inEvalCmdWithLocalReturnandtype(char const *,int *,enum inDebugCheck)(0, 0, 0x78fcc9d8 "C:\Documents and Settings\00\App..", 1) + 86 bytes
  [70] m_interpreter.dll:_inEvalCmd(0x79c71190 "matlabrc", 0x105ff410, 0, 0x015c54e0) + 17 bytes
  [71] bridge.dll:_mnRunLoginScript(0x015c1e58, 0x793025ee, 0, 0x015c5d08 "燭@") + 401 bytes
  [72] bridge.dll:int __cdecl mnRunPathDependentInitialization(void)(0x015c1e58, 0, 0x015c5d08 "燭@", 0x00cdf4fb) + 17 bytes
  [73] mcr.dll:public: __thiscall mcrInstance::mcrInstance(class mcrOptions &,class MfileReader *)(0x00cdff04, 0x005c5d08, 271241, 0x6d5c3a46) + 373 bytes
  [74] MATLAB.exe:0x00401c86(4194304, 0, 271241, 0x015c1e58)
  [75] MATLAB.exe:0x00403e45(3604531, 3342393, 0x7ffd6000, 0x8054b6ed)
  [76] kernel32.dll:0x7c816fd7(0x00403cc0 "jth(U@", 0, 0, 0)
Please follow these steps in reporting this problem to The MathWorks so
that we have the best chance of correcting it:
  1. Send this crash report to segv@mathworks.com for automated analysis.
     For your convenience, this information has been recorded in:
       C:\DOCUME~1\00\LOCALS~1\Temp\matlab_crash_dump.1916
  2. Also, if the problem is reproducible, send the crash report to
     support@mathworks.com along with:
       - A specific list of steps that will reproduce the problem
       - Any M, MEX, MDL or other files required to reproduce the problem
       - Any error messages displayed to the command window
     A technical support engineer will contact you with further information.
Thank you for your assistance.  Please save your workspace and restart
MATLAB before continuing your work.
Error in ==> whitebg at 96
lum = [.298936021 .58704307445 .114020904255]*c';
Error in ==> colordef>wdefault at 103
whitebg(fig,[1 1 1])
Error in ==> colordef at 50
  wdefault(fig)
Error in ==> hgrc at 59
colordef(0,'white') % Set up for white defaults
Error in ==> matlabrc at 89
hgrc
The element type "name" must be terminated by the matching end-tag "</name>".
Could not parse the file: f:\matlab\toolbox\ccslink\ccslink\info.xml
>> a=rand(2)
发表于 2007-10-11 12:23 | 显示全部楼层
回复 #1 asa 的帖子
重新装一下吧。这个问题很少遇到这样的问题
 楼主| 发表于 2007-10-11 12:40 | 显示全部楼层
回复 #2 无水1324 的帖子
我同学的是inter的CPU,我同样给她装的,她那一个没任何问题~~~郁闷死我了~~我又要用到matlab上课了~~~急死人呢~~
发表于 2007-10-11 12:42 | 显示全部楼层
回复 #3 asa 的帖子
哈哈哈,那时你运气背了,我这里全部是同一型号的机子,但是有些都会出现一些莫名其妙的现象。装matlab很快的
 楼主| 发表于 2007-10-11 12:43 | 显示全部楼层
回复 #4 无水1324 的帖子
该怎么办呢?
发表于 2007-10-11 12:48 | 显示全部楼层
回复 #5 asa 的帖子
重新装一下matlab
 楼主| 发表于 2007-10-11 12:54 | 显示全部楼层
回复 #6 无水1324 的帖子
我是从网上下载的,给同学装没问题,而且我也关掉杀毒软件重装了一次呢,俩字“没用”~~~:@( :@(
发表于 2007-10-11 13:19 | 显示全部楼层
那我就不会了。
发表于 2007-10-11 16:48 | 显示全部楼层
关闭windows防火墙和自己安装的防火墙看看
发表于 2007-10-11 16:58 | 显示全部楼层
有时网上下载的mATLAB源文件在解压时可能出现错误
发表于 2007-10-11 18:23 | 显示全部楼层
也有可能是系统问题
发表于 2007-10-12 19:56 | 显示全部楼层
有些问题就是很奇怪 等想明白了 估计系统都可以重装好几遍了
先重装matlab吧  不行重装系统
嘿嘿 偶向来是拿重装系统当法宝用的 虽然有点费时间 但不要怎么动脑筋 很多问题一刃而解
发表于 2007-10-12 20:40 | 显示全部楼层
呵呵,确实,有些时候软件就是这么讨厌的,对一些机器有点过敏现象,建议还是把系统恢复一下再装matlab吧!
 楼主| 发表于 2007-10-12 23:39 | 显示全部楼层
谢谢大家这么帮忙,有没有跟我这CPU一样,而且也能成功装好matlab的,最好是把那个网址告诉我,谢谢~~
发表于 2007-10-13 11:03 | 显示全部楼层
不一定是cpu的问题,你重装系统一下,然后装matlab,碎了你装在那张盘上?
GMT+8, 2025-1-25 11:25 , Processed in 0.082234 second(s), 17 queries , Gzip On.
