查看: 4671|回复: 2
[UDF专题] [求助]高手帮帮我!!
发表于 2005-12-4 09:46 | 显示全部楼层 |阅读模式
我在计算内螺纹管超临界水的传热,选的是RNG k-e模型,入口条件为质量入口,出口为OUTFLOW;其工质物性用UDF处理,问题好像就处在物性这里(保证UDF程序没有问题):当将粘度的UDF 加上,就会出错(错误烦请详见附件),如果将粘度设为一定值,就可以。为什么??
请给我帮助!!!!谢谢!
iter continuity x-velocity y-velocity z-velocity energy k epsilon time/iter
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 91960 cells
18 5.9446e-02 5.1724e-03 3.2169e-03 3.2276e-03 1.6463e-05 1.0998e-02 3.0948e-02 16:24:45 10000
Error: divergence detected in AMG solver: epsilon
Error Object: ()
reversed flow in 508 faces on outflow 5.
Error: divergence detected in AMG solver: x-momentum
Error Object: ()
Error Object: ()
Error Object: ()
Error Object: ()
Error Object: ()
Error Object: ()
Error Object: ()
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
temperature limited to 1.000000e+00 in 5 cells on zone 2
temperature limited to 5.000000e+03 in 9 cells on zone 3
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 61 cells
19 1.4495e+03 3.1185e-01 2.2079e-01 2.4335e-01 1.9082e-05 2.7210e+00 1.1999e+06 16:27:42 9999
reversed flow in 499 faces on outflow 5.
Error: divergence detected in AMG solver: temperature
Error Object: ()
发表于 2005-12-4 09:54 | 显示全部楼层
回复:(wangweishu)[求助]高手帮帮我!!
改小Under-Relaxation Factors中的步长看看
 楼主| 发表于 2005-12-4 11:37 | 显示全部楼层
我理解“改小Under-Relaxation Factors中的步长看看” ,就是改小松弛因子吧,我试了所有的松弛因子都小于0.3,但还是不行。还有别的办法????
GMT+8, 2024-11-26 08:25 , Processed in 0.058459 second(s), 17 queries , Gzip On.
