查看: 2865|回复: 6
[Fluent应用] 风力发电机叶片的CFD模拟 这个是怎么做出来的?
发表于 2007-9-23 11:01 | 显示全部楼层 |阅读模式
风力发电机叶片的CFD模拟
2007817 - 工程流体网
Thomas Hahm and Jürgen Kröning, TÜV Nord e.V., Hamburg, Germany
Many companies throughout the world have been applying their skills and expertise to the development of renewable energy sources. The number of companies involved in the production of clean and sustainable energy will undoubtedly increase in the near future due in part to a commitment to the Kyoto Protocol (1997), which calls for sweeping reductions in man-made green-house gas emissions, and in part to an increased awareness of the environment.
One of the most abundant sources of renewable energy is wind, and technology exists today for the efficient extraction of energy from wind for power generation. The efficiency of wind power is tied to a number of factors, one of which is the positioning of wind turbines near other wind turbines or structures. Decreased distances give rise to wake effects for the downstream units, which can lead to changeable wind loads, reduced energy yield, and vibration induced fatigue on the rotors and potentially on nearby power lines.
One popular operation concept for wind turbines allows for adjustments in the blade pitch to deliver a reasonably constant power output when there are variations in the wind speed. The wake behind these so-called “pitch-regulated” wind turbines depends on a number of parameters, such as blade geometry, pitch angle, and rotor speed on the hardware side and wind velocity, turbulence characteristics, and wind gradients on the environmental side. The large number of governing parameters makes it difficult to judge whether wake influences will lead to loads not considered during the original construction process. In a recent series of simulations at TÜV Nord e.V., FLUENT has been used to examine the wakes behind wind turbines of this type on the basis of their geometry and operating characteristics.
TÜV Nord e.V. is one of Germany’s Technical Inspection Agencies and has the goal of protecting humanity, the environment, and property against detrimental effects caused by technical installations and systems of every kind. To this end, it promotes the economic installation or manufacture and use of technical equipment, production, and operating facilities.
In a typical simulation, approximately 650 data points are used to create the geometry of a single rotor blade. A fine grid on the whole rotor surface is used to create a volume mesh of about 750,000 cells that gradually coarsens as the distance from the blades increases. The dimensions of the flow domain are adjusted to suit the needs of the specific problem. Downstream distances of six to ten times the rotor diameter have been modeled so far. The multiple reference frames (MRF) model is used to account for the rotation of the blades. Blade pitch, wind speed and direction, turbulence intensity and length scale, and rotor speed are input for each simulation.
Velocity contours behind one turbine show the wake effect on a second, smaller turbine
The geometry (front) and typical surface mesh (back) of a turbine rotor and hub To validate the CFD model, wake measurements behind a 55 kW pitch-regulated turbine were taken from the literature [Ref. 1]. Despite some inconsistencies in the measured wind velocities, good agreement between the measurements and calculated values was obtained. In addition, calculations presented in Reference 1, based on a simpler model that did not use the blade geometry, were not able to predict flow details that were captured by the 3D FLUENT runs. In particular, the enhancement of wind velocity at the edges of the wake could only be predicted by the CFD calculations, even though the magnitude of the enhancement was larger than the measured value.
Once the model was validated, it was used for several investigations of wake effects. On the previous page, one wind turbine is shown operating in the wake of a second, larger turbine. A wind velocity of 12.5 m/sec, with a turbulence intensity of 13%, was imposed upstream of the front turbine. Filled contours of constant mean velocity in the plane of the smaller turbine, four diameters behind the front turbine, show that the velocity field is nonuniform and not centered on the hub. Line contours in the plane containing the two turbines illustrate the decay in the wake as a function of distance behind the turbine. These results were used to help analyze the special wake loads experienced by the rear turbine.
Velocity magnitude slightly downstream of the rotor plane
Velocity magnitude in the wake of a wind turbine In another example, the excitation of vibrations in a power line was studied. Wind speeds in the range of 1 to 7 m/s and normal to the direction of the power line are most likely to cause these vibrations [Ref. 2]. If there is a considerable shift in the wind speeds due to wake loadings on the power line, the installation of vibration dampers on the power lines might be indicated. In the case studied, where the power line runs 25m above the ground, well below the turbine hub, the wake passes over the power line without causing any interference.
Currently, there is little data available for the turbulence intensity in the vicinity of installed wind turbines, and this point requires further investigation. Today, different empirical models are used to predict turbulence intensity in the wake of wind turbines [Ref. 3, 4]. Since these models only predict single averaged values along the wake axis and differ from one another, they cannot be used to validate the CFD calculations. The distribution of turbulence intensity computed by FLUENT in the wake region is in reasonably good agreement with theory. Absolute values, however, fall well below measured turbulence intensities due to effects not captured in the current model (e.g. tip vortices and wake meandering). Nonetheless, the flexibility and increased rigor of the CFD calculations, when compared to the simpler models, suggests that this methodology can offer improved insight into the efficient production of wind energy in the years to come.
In summary, given the rotor geometry and operating characteristics, CFD calculations are able to predict the wind velocities inside the wake of a wind turbine. Specific operating conditions, such as pitch angle and rotor speed, can easily be analyzed. Three-dimensional simulations of wind turbines can also be extended to include landscape topography (see Article 3) and other objects located in or near the wake.
Path lines through the turbine colored by velocity magnitude References : 1. Beyer, H.G. et. al.; Messungen von Windgeschwindigkeit und Turbulenz in der Nachlaufströmung eines 55 kW Windenergiekonverters mit variabler Drehzahl (Measurement of windspeed profiles and turbulence in the flow after a 55 kW wind energy converter with variable speed); DEWEK ’92, Deutsche Windenergie-Konferenz 1992; Wilhelmshaven 1993.
2. Degener, T.; Kießling, F.; Tzschoppe, J.; Mindestabstand zwischen Windenergieanlagen und Freileitungen (Minimum distance between wind energy plants and overhead lines); Elektrizitätswirtschaft Jg. 98 (1999), No. 7, p. 32-35.
3. Dekker, J.W.M.; Pierik, J.T.G. (Eds); European Wind Turbine Standards II; Petten, The Netherlands: ECN Solar & Wind Energy, 1998.
4. Frandsen, St.; Thogersen, L.; Integrated Fatigue Loading for Wind Turbines in Wind Farms by Combining Ambient Turbulence and Wakes; Wind Engineering, Vol. 23, No. 6, 1999.
 楼主| 发表于 2007-9-23 11:02 | 显示全部楼层
这个用fluent的网格是怎么划分的?请高手帮帮忙 我qq 84788999
发表于 2007-9-24 17:08 | 显示全部楼层
搞个非常大的计算域(这个区域你的去看文献到底多大才合适),在风叶在的位置圈出一个圆柱作为moving zone 平时怎么画网格这个也怎么画。
采用mfr模型。  我以前搞电机通风就这样干过
 楼主| 发表于 2007-9-27 09:46 | 显示全部楼层
太谢谢了 怎么联系你!!!?pengjc1983
发表于 2007-10-3 18:00 | 显示全部楼层
参考旋转机械的算例就可以。不过风力机的计算现在来说还比较难,由于流体不可控,以及尾流问题,计算精确度不高
 楼主| 发表于 2007-10-5 08:33 | 显示全部楼层
恩是的 呵呵 但是参考风扇的算例 好像不怎么行 慢慢学吧 !!!
发表于 2007-10-8 10:48 | 显示全部楼层
GMT+8, 2024-11-25 19:37 , Processed in 0.134557 second(s), 28 queries , Gzip On.
