查看: 1857|回复: 1
[数学理论] 请问Sotomayor 定理的a3条件是什么意思?
发表于 2007-9-22 10:40 | 显示全部楼层 |阅读模式
在判定saddle-node bifurcation的时候有个著名的定理是Sotomayor Theorem
Let dot(x)=f(x,u) be a system of differential equations in Rn. When u=u0, assume that there is an equilibrium p for which the following hypotheses are satisfied:
a1: Dxf(p) has a simple eigenvalue o with right eigenvector v and left eigenvector w.
a3: w(Dxxf(p)(v,v)) 不等于零.
 楼主| 发表于 2007-9-25 16:31 | 显示全部楼层
竟然没有人会啊
GMT+8, 2025-1-10 11:06 , Processed in 0.070449 second(s), 17 queries , Gzip On.
