查看: 5208|回复: 3
[前处理] [求助]interface,interior,internal boundary?
发表于 2005-11-29 20:36 | 显示全部楼层 |阅读模式
大侠们,请问interface,interior,internal boundary? 的区别是什么啊?
我现在建立了一个体,我用一个面把它split成两个体了(选了connected),我的目的是要分块划分网格。网格现在划分好了,但现在设置边界条件了,这些体的连接面要如何设置啊,(流体要流过中间面的),是interface,还是interior,还是internal 啊?
在FLUENT 里如何设置呢?
谢谢了
发表于 2005-11-29 21:30 | 显示全部楼层
回复:(lxh076412)[求助]interface,interior,intern...
我记得以前我split后,用connect把分界面连接起来,然后再划分网格就不需要考虑这个问题了
发表于 2005-11-29 21:46 | 显示全部楼层
the interface condition is needed for connecting different grid in a model : non matching interface, sliding mesh interface, and so on
the interior condition is usefull if you have surfaces in you model which are part of the fluid. If you don't use interior condition gambit can considerer them as wall.
the internal condition is quite the same as interior but it will be merge in the adjacent interiors in the final mesh if you use tgrid. I think that this condition is useless if you use gambit
 楼主| 发表于 2005-11-30 09:45 | 显示全部楼层
thank you very much!
GMT+8, 2024-11-26 09:57 , Processed in 0.054707 second(s), 18 queries , Gzip On.
