查看: 3293|回复: 6
[经典算法] 微分求积法(Differential Quadrature Method)
发表于 2007-9-9 14:09 | 显示全部楼层 |阅读模式
微分求积法,简称 DQ,是一种求解常微分和偏微分方程(组)的有效方法。将常微分和偏微分方程(组)经过DQ离散成线性或非线性方程组后可通过Newmark 和 Newton-Rapuson 求解,也可以直接使用Runge-Kutta法。但是本人在使用这些方法是遇到了困难,主要的问题是边界条件的处理,之后编程和算法上,因为它的离散过程是简单的!很希望和正在或曾经使用此方法的朋友交流,并虚心请教!
发表于 2007-10-12 09:39 | 显示全部楼层
参考下面的程序吧
  1. % Determination of the coefficients in DQM
  2. %   19/03/2006 By Dr. Yang J., Modified by Mr. Xiang H.J.
  3. %   Department of BC, City University of Hong Kong, Hong Kong
  4. %   [C,X]=DQC(N,M,KOP)
  5. %   KOP, Keyoption. 1--uniform space pattern; 2,3--cosine space pattern
  6. %   N--Total grid point; M--Order
  7. function [C,X]=DQC(N,M,KOP)
  8. %1. Generation of grid point coordinates in X-axis
  9. for i=1:N
  10.     X1(i)=(i-1)/(N-1);
  11.     X2(i)=0.5*(1-cos(pi*(i-1)/(N-1)));
  12. end
  13. X3(1)=0;X3(2)=0.00000001;%0.00001;
  14. for i=3:N
  15.      X3(i)=0.5*(1-cos(pi*(i-1)/(N-1)));
  16. end
  17. X4(1)=0;X4(2)=0.00001;X4(N-1)=0.99999;X4(N)=1.0;
  18. for i=3:N-2
  19.      X4(i)=0.5*(1-cos(pi*(i-2)/(N-3)));
  20. end
  21. X5(1)=0;X5(2)=0.00001;X5(3)=0.001;
  22. X5(N-2)=0.999;X5(N-1)=0.99999;X5(N)=1.0;
  23. for i=4:N-3
  24.      X5(i)=0.5*(1-cos(pi*(i-3)/(N-5)));
  25. end
  26. if KOP==1
  27.     X=X1;
  28. elseif KOP==2
  29.     X=X2;
  30. elseif KOP==3
  31.     X=X3;
  32. elseif KOP==4
  33.     X=X4;
  34. else
  35.     X=X5;
  36. end
  37. %2.   Producing the weighting coefficients
  38. %2.1 Producing the first-order weighting coefficients
  39. C=zeros(N,N,M);
  40. for i=1:N
  41.     Q(i)=1.0;
  42.     for j=1:N
  43.        if i~=j
  44.           Q(i)=Q(i)*(X(i)-X(j));
  45.        end
  46.     end
  47. end
  48. for i=1:N
  49.     for j=1:N
  50.         if i~=j
  51.           C(i,j,1)=Q(i)/(X(i)-X(j))/Q(j);
  52.           C(i,i,1)=C(i,i,1)-C(i,j,1);
  53.        end
  54.     end
  55. end
  56. %2.2 Producing the High-order weighting coefficients
  57. if M>1
  58.    for k=2:M
  59.      for i=1:N
  60.       for j=1:N
  61.        if i~=j
  62.           C(i,j,k)=k*(C(i,i,k-1)*C(i,j,1)-C(i,j,k-1)/(X(i)-X(j)));
  63.           C(i,i,k)=C(i,i,k)-C(i,j,k);
  64.        end
  65.       end
  66.      end
  67.    end
  68. end
来自:http://hi.baidu.com/hjxiang/blog ... 43902fb93820fb.html
 楼主| 发表于 2007-10-26 16:55 | 显示全部楼层
回复 #2 风花雪月 的帖子
谢谢!这个我已经做过了,而且已经用C重新写了一遍。现在的问题就是求解二阶微分方程了,我要用4阶龙格库塔法!正在思考。其实我倒自己写了一个,但是不是很好用。算起来很慢,不知道为什么!楼主,能不能帮着找一找更好的程序!
发表于 2007-10-26 23:33 | 显示全部楼层
回复 #3 su200703 的帖子
我想问一下,为什么不直接用ode45这些,命令直接求解,这个方法精度更高吗?
发表于 2007-12-6 09:26 | 显示全部楼层
原帖由 su200703 于 2007-10-26 16:55 发表
谢谢!这个我已经做过了,而且已经用C重新写了一遍。现在的问题就是求解二阶微分方程了,我要用4阶龙格库塔法!正在思考。其实我倒自己写了一个,但是不是很好用。算起来很慢,不知道为什么!楼主,能不能帮着找 ...
rk法本来的效率就不高,龙格库塔法的程序网络上有很多,你可以借鉴,本站搜索一下就能找到
发表于 2007-12-6 09:28 | 显示全部楼层
原帖由 无水1324 于 2007-10-26 23:33 发表
ode45是变步长的,说不定楼主想用定步长或者用自己学习编程也未可知
发表于 2012-4-15 15:25 | 显示全部楼层
还与人看这个帖子吗?程序看不懂,谁给发个结合实例的?
GMT+8, 2024-12-28 13:35 , Processed in 0.069990 second(s), 19 queries , Gzip On.
