查看: 1368|回复: 1
[CFD及热分析] 求助!流固耦合的第四部流体结构求解循环如何在GUI中实现?
发表于 2007-8-30 09:09 | 显示全部楼层 |阅读模式
!!!!!  4.  Fluid-Structure Interaction Loop
loop=25               ! Maximum allowed number of loops
toler=0.005           ! Convergence tolerance for maximum displacement
*dim,dismax,array,loop   ! Define array of maximum displacement values
*dim,strcri,array,loop   ! Define array of convergence values
*dim,index,array,loop
*do,i,1,loop             !  Execute fluid -> structure solutions   do循环在GUI中怎么操作?
physics,read,fluid       ! Read in fluid environment
*if,i,ne,1,then
flda,iter,exec,100       ! Execute 100 global iterations for
*endif                   !    each new geometry
solve                    ! FLOTRAN solution
fini
! end of fluid portion
physics,read,struc       ! Read in structures environment
/assign,esave,struc,esav ! Files for restarting nonlinear structure
/assign,emat,struc,emat
*if,i,gt,1,then        ! Structural restart loop
parsave,all            ! Save parameters for convergence check
resume                 ! Resume DB - to return original node positions
parresume              ! Resume parameters needed for convergence check
/prep7
antype,stat,rest
fini
*endif
发表于 2009-4-10 09:30 | 显示全部楼层
顶!!!
最近做流固耦合分析,一直处于摸索中,最想知道这块怎么用GUI做呢!
GMT+8, 2025-1-26 11:33 , Processed in 0.130206 second(s), 20 queries , Gzip On.
