查看: 10147|回复: 5
[编程技巧] Subscripted assignment dimension mismatch 出错请教
发表于 2007-8-3 16:06 | 显示全部楼层 |阅读模式
我是初学者,在借助代码修改程序中出现问题,苦思多日不见出路,特向高手请教.程序如下:
global x;
x1(1,:)=[0.671796 0.919430 0.941397 0.438988 0.866638 0.201446 0.523668 0.408518 0.373441 0.491071 1.114654 1.155400 0.961947 1.094813 1.123866 0.350057 0.391865 0.246599 0.538903 0.502409 0.406430 0.456700 0.460840        0.397420 0.436510 0.483510 0.374620        0.377710 0.590160 0.523430 0.669290        0.665860 0.749950 0.605870 0.710390 0.625950 0.711690 0.499100 0.638230 0.511580 0.663890 0.636220 0.758930        0.528160 3.038550 0.798380 0.786560        0.771090 0.913760 0.606690];
x1(2,:)=[0.767520 0.676370 0.597390 0.562620 0.701980 0.727960 0.835730 0.571260 0.854420 0.842830 0.597410 0.649750 0.509080 0.708950 0.795860 0.955310 0.871440 0.914960 0.815090 0.906860 0.491800 0.541700 0.545900        0.470700 0.499200 0.552200 0.486200        0.458700 0.619100 0.575000 0.658900        0.660500 0.694800 0.641200 0.678700        0.622300 0.672600 0.540700 0.650700        0.541100 0.665800 0.660700 0.766800        0.580900 0.662400 0.757700 0.775700        0.742300 0.819000 0.628400];
x1(3,:)=[0.425500 1.400000 0.259300 0.255860 0.071340 0.041920 0.196130 0.119700 0.188000 0.194500 0.583500 0.230900 1.080000 0.068720 0.176560 0.043970 0.140240 0.160500 0.250200 0.174000 0.008670 0.713800 0.625100        0.172800 0.026740 0.318590 0.024710        0.170000 0.657100 0.303000 0.762700        1.320000 0.346400 0.276750 0.194680        0.281690 0.116280 0.159600 0.112300        0.119600 0.486700 1.150000 0.368300        0.351650 0.080900 0.208280 0.182530        0.105700 0.079850 0.002050];
success=0;
PopSize=20;
MaxIt=40;
iter=1;
fevals=0;%function evaluation'counter
maxw=1.2;%maximum interia weight's value
minw=0.1;%minimum interia weight's value
c1=0.5;
c2=0.5;
inertdec=(maxw-minw)/MaxIt;% weight decrease by same value, search change function of weight
w=maxw;
f='gold';
dim=3;
ErrGoal=1e-4;
%initializing swarm and velocity
vel=rand(dim,PopSize);
for i=1:3
   popul(i,:)=rand(1,PopSize)*(max(x1(i,:))-min(x1(i,:)))+min(x1(i,:))
%evaluation initial population
for i=1:PopSize
     x1=popul(1,i); %popul is 2D array,2D particle population
     x2=popul(2,i);
     x3=popul(3,i);
     fpopul(i)=feval(f,x1,x2,x3);   %fpopul is 1D array,function values of 2D particle population
     fevals=fevals+1;
     ppopul(:,i,iter)=popul(:,i);
bestpos=popul; % positions of  initial particle
fbestpos=fpopul;% func values of initial particle
%ppopul(:,:,iter)=ppopul;
% finding best particle in initial
[fbestpart(iter),g]=min(fpopul);% min value of population and index.
lastbpf=fbestpart(iter);% current values of optimal particle
%swarm evolution loop
while(iter<MaxIt)
    iter=iter+1;
    % update the value of inertia weight w
    if(iter<=MaxIt)
        w=maxw-(iter-1)*inertdec;
    %velocity update
    for i=1:PopSize
        A(:,i)=bestpos(:,g);% optical position of each particle is g.
        R1=rand(dim,PopSize);
        R2=rand(dim,PopSize);
        vel=w*vel+c1*R1.*(bestpos-popul)+c2*R2.*(A-popul);%local optical is bestpos,global optical is A.
        %swarm update
        popul=popul+vel;
        for i=1:3
            for j=1:PopSize
                 ppopul(i,j,iter)=popul(i,j);
            for i=1:PopSize
            x1=popul(1,i);
            x2=popul(2,i);
            x3=popul(3,i);
            fpopul(iter,i)=feval(f,x1,x2,x3);
            fevals=fevals+1;
        for i=1:PopSize
          if(fpopul(iter,i)<fbestpos(i))
           fbestpos(i)=fpopul(iter,i);
            bestpos(:,i)=popul(:,i);
          [fbestpart(iter),g]=min(fbestpos);
          if (abs(fbestpart(iter)-fbestpart(iter-1))<=ErrGoal)&(abs(fpopul(iter,1)-fpopul(iter-1,1))<=ErrGoal)
           break;
     xmin=popul(:,g)
    fxmin=fbestpos(g)
    bestpos
      subplot(2,2,1)
    a=iter/3;
    for i=1:a
       i=i*2;
       % text(xx1(i,1),yy1(i,1),zz1(i,1),['\leftarrow(',num2str(i),')'],'FontSize',6.0)
       plot3(ppopul(1,1,i),ppopul(2,1,i),ppopul(3,1,i),'linestyle','--','marker','.','markersize',3)
       xlabel('萼片长度/cm','fontsize',8),ylabel('花瓣高度/cm','fontsize',8),zlabel('花瓣宽度/cm','fontsize',8)
       title('粒子1优化过程轨迹','FontSize',8)
       axis([2.5  7 2 5 0 4])
            hold on
    iter
    fevals
  function sum=gold(x1,x2,x3)
   global x;
  sum=0;
     x1(1,:)=[0.671796 0.919430 0.941397 0.438988 0.866638 0.201446 0.523668 0.408518 0.373441 0.491071 1.114654 1.155400 0.961947 1.094813 1.123866 0.350057 0.391865 0.246599 0.538903 0.502409];
     x1(2,:)=[0.767520 0.676370 0.597390 0.562620 0.701980 0.727960 0.835730 0.571260 0.854420 0.842830 0.597410 0.649750 0.509080 0.708950 0.795860 0.955310 0.871440 0.914960 0.815090 0.906860];
     x1(3,:)=[0.425500 1.400000 0.259300 0.255860 0.071340 0.041920 0.196130 0.119700 0.188000 0.194500 0.583500 0.230900 1.080000 0.068720 0.176560 0.043970 0.140240 0.160500 0.250200 0.174000];
     for i=1:20
      sum=sum+0.126*(x(1,i)-x1)^2+0.505*(x(2,i)-x2)^2+0.368*(x(3,i)-x3)^2;
运行结果是:
??? Subscripted assignment dimension mismatch.
可能是gold生成过程中出错,可是不清楚怎么错的,
发表于 2007-8-3 16:22 | 显示全部楼层
原帖由 pier 于 2007-8-3 16:06 发表
global x;
x1(1,:)=[0.671796 0.919430 0.941397 0.438988 0.866638 0.201446 0.523668 0.408518 0.373441 0.491071 1.11 ...
根据matlab的出错提示,定位到程序具体代码中,然后设置断点,调试一下。详情请参阅各个置顶贴
 楼主| 发表于 2007-8-3 16:47 | 显示全部楼层
回复 #2 eight 的帖子
非常高兴能得到这么快的回复!!由衷地感到这个论坛的的负责人都特别认真!!谢谢eight!
继续上面的问题:
运行结果是:Error in ==> pso>gold at 124
Error in ==> pso at 34
因为采用的是gold优化序列(这个就是我用原来的标题的原因),结果运行的维度错误确实应该是关于gold,因此我主要想就gold这个优化序列指令的使用注意事项请教高手?
 楼主| 发表于 2007-8-3 19:46 | 显示全部楼层
自己解答
我自己来解答吧
运行过程中没有处理好下面一段:
for i=1:PopSize
     x2=popul(2,i);
     x3=popul(3,i);
     fevals=fevals+1;
因此,fpopul(i)=feval(f,x1,x2,x3)中的x2,x3等的脚标出现问题
发表于 2010-6-25 10:56 | 显示全部楼层
请问楼主是怎么解决的这个问题呢?我现在也遇到相似的问题了,想不出解决办法
发表于 2010-6-25 21:19 | 显示全部楼层
原帖由 苏静207 于 2010-6-25 10:56 发表
请问楼主是怎么解决的这个问题呢?...
5F???
GMT+8, 2025-1-11 00:21 , Processed in 0.068694 second(s), 19 queries , Gzip On.
