楼主: 无水1324
[其他相关] [讨论、交流]齿轮系统的动力学仿真
发表于 2008-2-5 08:35 | 显示全部楼层
den Hartog, J.P. and Mikina, S.J., 1932, “Forced vibrations with non-linear spring constants”, ASME Journal of Applied Mechanics, 58, pp.157-164
Comparin, R.J. and Singh, R., 1989, “Nonlinear frequency response characteristics of an impact pair”, Journal of Sound and Vibration, 134, pp.259-290.
Kahraman, A. and Singh, R., 1990, “Nonlinear dynamics of a spur gear pair”, Journal of Sound and Vibration, 142, pp.49-75.
Rook T. E. and Singh, R., 1995, “Dynamic Analysis of a reverse-idler gear pair with concurrent clearances”, Journal of Sound and Vibration, 182, pp.303-322.
Theodossiades, S. and Natsiavas, S., 2000, “Non-linear dynamics of gear-pair systems with periodic stiffness and backlash”, Journal of Sound and Vibration, 229(2), pp 287-310.
Pfeiffer, F. 1984, “Mechanische Systems mit unstetigen Ubergangen”, Ing. Archiv,  54, pp.232-240.
Karagiannis, K. and Pfeiffer, F., 1991, “Theoretical and experimental investigations of gear box”, Nonlinear Dynamics, 2, pp.367-387.
Luo, A.C.J. and Chen, L.D., 2005, “Periodic motion and grazing in a harmonically forced, piecewise, linear oscillator with impacts”, Chaos, Solitons and Fractals, 24, pp. 567-578.
Luo, A.C.J. and Chen L.D., 2007, “Arbitrary periodic motions and grazing switching of a forced piecewise-linear, impacting oscillator”, ASME Journal of Vibration and Acoustics, 129, pp.276-284.
You may get more recent papers from Pfeiffer and Singh's group.
发表于 2008-2-24 22:30 | 显示全部楼层
回复 楼主 的帖子
目前,本人正在做齿轮摩擦非线性动力学理论分析和实验,理论上单自由度和多自由度从本质上的计算分析一样,但如何实验验证比较难,可以做出混沌,但不能做了分岔,比较苦恼.不知有没有朋友直接得到分岔的实验结论,而不是通过其它如功率谱等的验证.
发表于 2008-2-24 22:37 | 显示全部楼层
谢谢,chaos2.你提供的几篇文献,有的我已看过,最后三篇还没有时间出查询,若能提供非常感谢!
发表于 2008-2-25 09:08 | 显示全部楼层
回复 48楼 的帖子
你的混沌实验是怎么做的啊,比较好奇,能否大致说一下如果不涉及保密的话
发表于 2008-2-25 10:56 | 显示全部楼层
我的硕士导师也是搞齿轮的,前阵子也和他说起过齿轮非线性动力学研究的问题,他说这方面是换汤不换药,特别是非线性试验方面,比较难实现,所以他不走这条路了!
发表于 2008-2-25 21:31 | 显示全部楼层
利用得到的振动信号,采用小波方式进行分析,并利用关联维数可以得到混沌运动信号.
 楼主| 发表于 2008-2-25 22:29 | 显示全部楼层
回复 51楼 的帖子
只能说可以利用关联维数判断混沌运动信号
发表于 2008-2-27 08:38 | 显示全部楼层
回复 47楼 的帖子
Could you please give your email address? you may ask Gary  to help you via
gary.rain@gmail.com
 楼主| 发表于 2008-2-27 16:41 | 显示全部楼层
回复 53楼 的帖子
这位大哥的的英语水平不错哈
发表于 2008-5-28 10:47 | 显示全部楼层
原帖由 aliaofly 于 2008-1-27 22:01 发表
请问:我的模型是斜齿轮系统十自由度弯扭轴摆耦合动力方程,其右端项的载荷在编程求解振动响应时该如何选取,是仅取扭转方向上的两个转矩,还是要代入所有自由度上的动态啮合力,在下很是困惑?
我现在也在学习斜齿轮的振动问题 请教一下 你的斜齿轮的刚度是怎么求出来的啊?我看了一些资料 不是很清楚 你是用有限元求解的刚度吗?谢谢
发表于 2008-6-12 09:40 | 显示全部楼层
前来报到:准备做一根轴上的齿轮-轴-轴承的耦合振动。由于刚刚接触振动。刚看了2本书。请教下做这个什么软件好、大家在帮我分析下影响这个耦合振动的因素有哪些?谢谢啦
 楼主| 发表于 2008-6-12 13:00 | 显示全部楼层
回复 47楼 的帖子
齿轮方面的摩擦试验应该很难的,你们的试验台搭建好了吗?
 楼主| 发表于 2008-6-12 13:03 | 显示全部楼层
回复 56楼 的帖子
做集中质量模型的话,就只好建立动力学模型,然后matlab做数值分析了。
发表于 2009-2-24 14:46 | 显示全部楼层
ANSYS-LSDYNA做齿轮动力学接触问题:
1、两齿轮接触,在加载的时候是不是两个齿轮的角速度和转距都要加上,还是只给主齿轮加角速度,从动轮加反转距?
2、两齿轮的转轴不在总体坐标系下,加载又该如何进行?
3、SHELL163单元和SOLID164单元该如何连接呢?因为需要SHELL163的角速度自由度
谢谢各位了!
发表于 2009-2-26 09:00 | 显示全部楼层
我做针齿摆线齿轮动力学分析的,考虑时便啮合刚度,间隙,误差等因素。
建立动力学模型,列微分方程
求稳态解
在做相图等等的
GMT+8, 2024-12-28 14:02 , Processed in 0.094983 second(s), 18 queries , Gzip On.
