查看: 2100|回复: 4
[电力电机类] svpwm s函数语句问题
发表于 2007-7-11 15:49 | 显示全部楼层 |阅读模式
麻烦大家 帮我看看下面这个s函数
我想要生成svpwm
结果建立函数模块的时候
总是报错
说是 倒数第三行的function位置不对或者错误嵌套
我都没动过这个函数
是不是我的if语句用的不对?
谢谢大家拉!!!
function [sys,x0,str,ts] = svpwm_2(t,x,u,flag)
%SFUNTMPL General M-file S-function template
%   With M-file S-functions, you can define you own ordinary differential
%   equations (ODEs), discrete system equations, and/or just about
%   any type of algorithm to be used within a Simulink block diagram.
%   The general form of an M-File S-function syntax is:
%       [SYS,X0,STR,TS] = SFUNC(T,X,U,FLAG,P1,...,Pn)
%   What is returned by SFUNC at a given point in time, T, depends on the
%   value of the FLAG, the current state vector, X, and the current
%   input vector, U.
%   FLAG   RESULT             DESCRIPTION
%   0      [SIZES,X0,STR,TS]  Initialization, return system sizes in SYS,
%                             initial state in X0, state ordering strings
%                             in STR, and sample times in TS.
%   1      DX                 Return continuous state derivatives in SYS.
%   2      DS                 Update discrete states SYS = X(n+1)
%   3      Y                  Return outputs in SYS.
%   4      TNEXT              Return next time hit for variable step sample
%                             time in SYS.
%   5                         Reserved for future (root finding).
%   9      []                 Termination, perform any cleanup SYS=[].
%   The state vectors, X and X0 consists of continuous states followed
%   by discrete states.
%   Optional parameters, P1,...,Pn can be provided to the S-function and
%   used during any FLAG operation.
%   When SFUNC is called with FLAG = 0, the following information
%   should be returned:
%      SYS(1) = Number of continuous states.
%      SYS(2) = Number of discrete states.
%      SYS(3) = Number of outputs.
%      SYS(4) = Number of inputs.
%               Any of the first four elements in SYS can be specified
%               as -1 indicating that they are dynamically sized. The
%               actual length for all other flags will be equal to the
%               length of the input, U.
%      SYS(5) = Reserved for root finding. Must be zero.
%      SYS(6) = Direct feedthrough flag (1=yes, 0=no). The s-function
%               has direct feedthrough if U is used during the FLAG=3
%               call. Setting this to 0 is akin to making a promise that
%               U will not be used during FLAG=3. If you break the promise
%               then unpredictable results will occur.
%      SYS(7) = Number of sample times. This is the number of rows in TS.
%      X0     = Initial state conditions or [] if no states.
%      STR    = State ordering strings which is generally specified as [].
%      TS     = An m-by-2 matrix containing the sample time
%               (period, offset) information. Where m = number of sample
%               times. The ordering of the sample times must be:
%               TS = [0      0,      : Continuous sample time.
%                     0      1,      : Continuous, but fixed in minor step
%                                      sample time.
%                     PERIOD OFFSET, : Discrete sample time where
%                                      PERIOD > 0 & OFFSET < PERIOD.
%                     -2     0];     : Variable step discrete sample time
%                                      where FLAG=4 is used to get time of
%                                      next hit.
%               There can be more than one sample time providing
%               they are ordered such that they are monotonically
%               increasing. Only the needed sample times should be
%               specified in TS. When specifying than one
%               sample time, you must check for sample hits explicitly by
%               seeing if
%                  abs(round((T-OFFSET)/PERIOD) - (T-OFFSET)/PERIOD)
%               is within a specified tolerance, generally 1e-8. This
%               tolerance is dependent upon your model's sampling times
%               and simulation time.
%               You can also specify that the sample time of the S-function
%               is inherited from the driving block. For functions which
%               change during minor steps, this is done by
%               specifying SYS(7) = 1 and TS = [-1 0]. For functions which
%               are held during minor steps, this is done by specifying
%               SYS(7) = 1 and TS = [-1 1].
%   Copyright 1990-2002 The MathWorks, Inc.
%   Revision:1.18
% The following outlines the general structure of an S-function.
n=u(1);
tt=u(2);
t0=u(3);
t1=u(4);
t2=u(5);
t7=u(6);
switch flag,
  % Initialization %
  case 0,
    [sys,x0,str,ts]=mdlInitializeSizes(n,tt,t0,t1,t2,t7);
  % Derivatives %
  case 1,
    sys=mdlDerivatives(t,x,u);
  % Update %
  case 2,
    sys=mdlUpdate(t,x,u);
  % Outputs %
  case 3,
    sys=mdlOutputs(t,x,u);
  % GetTimeOfNextVarHit %
  case 4,
    sys=mdlGetTimeOfNextVarHit(t,x,u);
  % Terminate %
  case 9,
    sys=mdlTerminate(t,x,u);
  % Unexpected flags %
  otherwise
    error(['Unhandled flag = ',num2str(flag)]);
% end sfuntmpl
% mdlInitializeSizes
% Return the sizes, initial conditions, and sample times for the S-function.
function [sys,x0,str,ts]=mdlInitializeSizes
% call simsizes for a sizes structure, fill it in and convert it to a
% sizes array.
% Note that in this example, the values are hard coded.  This is not a
% recommended practice as the characteristics of the block are typically
% defined by the S-function parameters.
sizes = simsizes;
sizes.NumContStates  = 0;
sizes.NumDiscStates  = 0;
sizes.NumOutputs     = 3;
sizes.NumInputs      = 6;
sizes.DirFeedthrough = 0;
sizes.NumSampleTimes = 1;   % at least one sample time is needed
sys = simsizes(sizes);
% initialize the initial conditions
x0  = [];
% str is always an empty matrix
str = [];
% initialize the array of sample times
ts  = [0 0];
% end mdlInitializeSizes
% mdlDerivatives
% Return the derivatives for the continuous states.
function sys=mdlDerivatives(t,x,u)
sys = [];
% end mdlDerivatives
% mdlUpdate
% Handle discrete state updates, sample time hits, and major time step
% requirements.
function sys=mdlUpdate(t,x,u)
sys = [];
% end mdlUpdate
% mdlOutputs
% Return the block outputs.
function sys=mdlOutputs(t,x,u,n,tt,t0,t1,t2,t7)
if n==1
   if t>=tt&t<tt+t0/2
  sys=[0 0 0];
  else if t>=tt+t0/2&t<tt+t0/2+t1/2
  sys=[1 0 0];
  else if t>=tt+t0/2+t1/2&t<tt+t0/2+t1/2+t2/2
  sys=[1 1 0];
  else if t>=tt+t0/2+t1/2+t2/2&t<tt+t0/2+t1/2+t2/2+t7
  sys=[1 1 1];
  else if t>=tt+t0/2+t1/2+t2/2+t7&t<tt+t0/2+t1/2+t2+t7
sys=[1 1 0];
  else if t>=tt+t0/2+t1/2+t2+t7&t<tt+t0/2+t1+t2+t7
  sys=[1 0 0];
  else
  sys=[0 0 0];
if n==2
  if t>=tt&t<tt+t7/2
  sys=[1 1 1];
  else if t>=tt+t7/2&t<tt+t7/2+t1/2
  sys=[1 1 0];
  else if t>=tt+t7/2+t1/2&t<tt+t7/2+t1/2+t2/2
  sys=[0 1 0];
  else if t>=tt+t7/2+t1/2+t2/2&t<tt+t7/2+t1/2+t2/2+t0
  sys=[0 0 0];
  else if t>=tt+t7/2+t1/2+t2/2+t0&t<tt+t7/2+t1/2+t2+t0
  sys=[0 1 0];
  else if t>=tt+t7/2+t1/2+t2+t0&t<tt+t7/2+t1+t2+t0
  sys=[1 1 0];
  else
  sys=[1 1 1];
if n==3
  if t>=tt&t<tt+t0/2
  sys=[0 0 0];
  sys=[0 1 0];
  sys=[0 1 1];
sys=[1 1 1];
  sys=[0 1 1];
  sys=[0 1 0];
  else
  sys=[0 0 0];
if n==4
  if t>=tt&t<tt+t7/2
  sys=[1 1 1];
sys=[0 1 1];
  sys=[0 0 1];
  sys=[0 0 0];
  sys=[0 0 1];
  sys=[0 1 1];
  else
  sys=[1 1 1];
if n==5
  if t>=tt&t<tt+t0/2
  sys=[0 0 0];
  sys=[0 0 1];
  sys=[1 0 1];
sys=[1 1 1];
  sys=[1 0 1];
  sys=[0 0 1];
  else
  sys=[0 0 0];
if n==6
  if t>=tt&t<tt+t7/2
  sys=[1 1 1];
  sys=[1 0 1];
  sys=[1 0 0];
  sys=[0 0 0];
  sys=[1 0 0];
  sys=[1 0 1];
   else
  sys=[1 1 1];
% end mdlOutputs
% mdlGetTimeOfNextVarHit
% Return the time of the next hit for this block.  Note that the result is
% absolute time.  Note that this function is only used when you specify a
% variable discrete-time sample time [-2 0] in the sample time array in
% mdlInitializeSizes.
% end mdlGetTimeOfNextVarHit
% mdlTerminate
% Perform any end of simulation tasks.
function sys=mdlTerminate(t,x,u)
sys = []; % end mdlTerminate
% end mdlTerminate
发表于 2007-8-22 15:36 | 显示全部楼层
if 与and 不匹配
发表于 2007-8-24 11:37 | 显示全部楼层
回复 #2 wenchx 的帖子
你的这个函数中,输入量tt是什么意思,t是指当前仿真时间吗
发表于 2007-8-24 16:20 | 显示全部楼层
%   input vector, U.
%                             time in SYS.
%                                      sample time.
%                                      next hit.
%               seeing if
%   Revision:1.18
switch flag,
  % Initialization %
  case 0,
    [sys,x0,str,ts] = mdlInitializeSizes;
  % Derivatives %
  %case 1,
    %sys=mdlDerivatives(t,x,u);
  % Update %
  %case 2,
  %  sys=mdlUpdate(t,x,u);
  % Outputs %
  case 3,
  %case 4,
  %  sys=mdlGetTimeOfNextVarHit(t,x,u);
  % Terminate %
  case {1,2,4,9},% different
    sys=[];
  otherwise
% end sfuntmpl
% sizes array.
sizes = simsizes;
x0  = [];
str = [];
ts  = [0 0];
% mdlDerivatives
%function sys=mdlDerivatives(t,x,u)
%sys = [];
% mdlUpdate
% requirements.
%function sys=mdlUpdate(t,x,u)
%sys = [];
% end mdlUpdate
% mdlOutputs
function sys=mdlOutputs(t,x,u)
n=u(1);
tt=u(2);
t0=u(3);
t1=u(4);
t2=u(5);
t7=u(6);
if n==1
   if t>=tt && t<tt+t0/2
   sys=[0 0 0];
   elseif t>=tt+t0/2 && t<tt+t0/2+t1/2
   sys=[1 0 0];
   elseif t>=tt+t0/2+t1/2 && t<tt+t0/2+t1/2+t2/2
   sys=[1 1 0];
   elseif t>=tt+t0/2+t1/2+t2/2 && t<tt+t0/2+t1/2+t2/2+t7
   sys=[1 1 1];
   elseif t>=tt+t0/2+t1/2+t2/2+t7 && t<tt+t0/2+t1/2+t2+t7
   sys=[1 1 0];
   elseif t>=tt+t0/2+t1/2+t2+t7 && t<tt+t0/2+t1+t2+t7
   sys=[1 0 0];
   else
   sys=[0 0 0];
if n==2
  if t>=tt && t<tt+t7/2
  sys=[1 1 1];
  elseif t>=tt+t7/2 && t<tt+t7/2+t1/2
  sys=[1 1 0];
  elseif t>=tt+t7/2+t1/2 && t<tt+t7/2+t1/2+t2/2
  sys=[0 1 0];
  elseif t>=tt+t7/2+t1/2+t2/2 && t<tt+t7/2+t1/2+t2/2+t0
  sys=[0 0 0];
  elseif t>=tt+t7/2+t1/2+t2/2+t0 && t<tt+t7/2+t1/2+t2+t0
  sys=[0 1 0];
  elseif t>=tt+t7/2+t1/2+t2+t0 && t<tt+t7/2+t1+t2+t0
  sys=[1 1 0];
  else
  sys=[1 1 1];
if n==3
  sys=[0 0 0];
  sys=[0 1 0];
  sys=[0 1 1];
sys=[1 1 1];
  sys=[0 1 1];
  sys=[0 1 0];
  else
  sys=[0 0 0];
if n==4
  sys=[1 1 1];
  sys=[0 1 1];
  sys=[0 0 1];
  sys=[0 0 0];
  sys=[0 0 1];
  sys=[0 1 1];
  else
  sys=[1 1 1];
if n==5
  sys=[0 0 0];
  sys=[0 0 1];
  sys=[1 0 1];
  sys=[1 1 1];
  sys=[1 0 1];
  sys=[0 0 1];
  else
  sys=[0 0 0];
if n==6
  sys=[1 1 1];
  sys=[1 0 1];
  sys=[1 0 0];
  sys=[0 0 0];
  sys=[1 0 0];
  sys=[1 0 1];
  else
  sys=[1 1 1];
% end mdlOutputs
% mdlTerminate
%function sys=mdlTerminate(t,x,u)
%sys = []; % end mdlTerminate
% end mdlTerminate
发表于 2007-8-24 16:23 | 显示全部楼层
因为没有运行环境,没有flag的值,所以我只能调到这个程度了,你试试看吧,我也刚刚开始用matlab编程
另外,elseif是连写的不能分开
GMT+8, 2025-3-13 17:23 , Processed in 0.056437 second(s), 19 queries , Gzip On.
