查看: 2059|回复: 1
执行的时候出现这个错误请问是什么原因
发表于 2007-7-3 21:10 | 显示全部楼层 |阅读模式
现在出现这个错误,不知道有没有出现类似错误的同行,帮忙指教指教,是什么原因呢
我的是调用子程序,执行后出现的.
The executable C:\ABAQUS\6.5-1\exec\standard.exe aborted with system error code 29539. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run ABAQUS that you used when the problem occurred.  Please contact your local ABAQUS support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
发表于 2007-7-4 15:12 | 显示全部楼层
你的子程序有问题!用abaqus job=support information=support来看具体一点的问题
如果没有子程序
这将意味着ABAQUS本身的缺陷!!
GMT+8, 2025-1-6 13:57 , Processed in 0.071387 second(s), 17 queries , Gzip On.
