查看: 1717|回复: 3
[编程技巧] 程序出错
发表于 2007-6-9 15:40 | 显示全部楼层 |阅读模式
我有一个程序运行老出错,请高人指点.
我把程序简化一下,是这样的:
rou1=7850
d=10^(-3).*[9,9,17,17,17,17,17,17,17,17]
l=10^(-3).*[4,4,10.75,10.75,10.75,10.75,11,11,7.75,7.75]
u=rou1.*pi.*d.^2./4;
jp=0.5.*u.*d.^2./4;
jd=u./12.*(3.*d.^2./4+l.^2);
显示的结果是:
jp =
  1.0e-004 *
    0.0506    0.0506    0.6437    0.6437    0.6437    0.6437    0.6437    0.6437    0.6437    0.6437
jd =
  1.0e-004 *
    0.0319    0.0319    0.4934    0.4934    0.4934    0.4934    0.5015    0.5015    0.4110    0.4110
一切显示正常.
但是我实际计算中d和l是80列的向量.结果就出错.我真的不知道错在那里
d=10^(-3).*[9,9,17,17,17,17,17,17,17,17,17,17,18,18,18,18,18,18,18,18,18,18,22,22,22,22,22,22,24,24,24,24,44,44,39.7,39.7,26,26,26,22,22,22,22,21,21,21,21,19,19,19,19,19,19,19,19,19,19,18,18,18,18,18,18,18,18,18,18,17,17,17,17,17,17,17,17,17,17,9,9,9];
l=10^(-3).*[4,4,10.75,10.75,10.75,10.75,11,11,7.75,7.75,7.75,7.75,9.75,9.75,9.75,9.75,11,11,10,10,10,10,9.83,9.83,9.83,9.83,9.83,9.83,13,13,4.5,4.5,12,12,13,13,16.33,16.33,16.33,17.25,17.25,17.25,17.25,16,16,16,16,10,10,10,10,11,11,7.25,7.25,7.25,7.25,10.25,10.25,10.25,10.25,11,11,9.75,9.75,9.75,9.75,7.75,7.75,7.75,7.75,11,11,10.75,10.75,10.75,10.75,4,4,4];
rou1=7850
jp=0.5.*u.*d.^2./4;
显示的结果是:
jp =
  Columns 1 through 16
    0.0000    0.0000    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001
  Columns 17 through 32
    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0002    0.0002    0.0002    0.0002    0.0002    0.0002    0.0003    0.0003    0.0003    0.0003
  Columns 33 through 48
    0.0029    0.0029    0.0019    0.0019    0.0004    0.0004    0.0004    0.0002    0.0002    0.0002    0.0002    0.0001    0.0001    0.0001    0.0001    0.0001
  Columns 49 through 64
    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001
  Columns 65 through 80
    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0001    0.0000    0.0000    0.0000
为何jp的很多列为0,请指教.
发表于 2007-6-9 16:04 | 显示全部楼层
原帖由 gh688 于 2007-6-9 15:40 发表
我有一个程序运行老出错,请高人指点.
我把程序简化一下,是这样的:
rou1=7850
u=rou1.*pi.*d.^2./4; ...
你说“正常”的情况也不见得正常,因为结果都接近0(看到前面的 1e-004 吗);至于“不正常”的情况,估计是显示精度问题,help
format, digits 吧
[ 本帖最后由 eight 于 2007-6-9 16:19 编辑 ]
 楼主| 发表于 2007-6-9 16:18 | 显示全部楼层
thanks
用digits 我解决这个问题了,果然是精度问题,多谢
发表于 2007-6-9 22:09 | 显示全部楼层
用 format long
或者画成图形检查
GMT+8, 2025-1-30 11:23 , Processed in 0.071850 second(s), 17 queries , Gzip On.
