查看: 3295|回复: 5
[ADAMS专区] 请问有关汽车模型仿真的问题?
发表于 2007-6-5 09:05 | 显示全部楼层 |阅读模式
模型是下载的TRUCK模块,在ADAMS/CAR里运算仿真时,出错,请高手或是版主给个答案,谢谢。
Reading in property files...
Reading of property files completed.
Setting up the vehicle assembly for Driving Machine maneuver...
The engine map output communicator has not been found in the powertrain subsystem.
Using max driving/braking torque variables.
The front/rear wheel/tire assembly has not been found.
Setting default values for SmartDriver Pro.
Setup of vehicle assembly completed.
Simulation is beginning...
Starting analysis #1 of vehicle assembly...
   *                 MSC.Software Corporation                   *
   *                  A D A M S / S o l v e r                   *
   *      Automatic Dynamic Analysis of Mechanical Systems      *
   *      2007-06-05 08:55:17              Version 2005.2.0     *
   Enter ADAMS model file name or Carriage Return or ? (or STOP):
   No model input file (ADM file) is given.
   Enter Command:
   file/model=k_accel
   A new model supplied.  Initialization starts...
   The default input and analysis values will be restored.
   CPU time used = 4.68750E-02 seconds
   ADAMS/Car 2005.2.0
   ID = 1
   Enter ADAMS output file name or ? (default is same as input):
     ADAMS model file .. k_accel.adm
   Default file names for output files
     Tabular output file:
     k_accel.out
     Diagnostic file    :
     k_accel.msg
     Message Database file    :
     k_accel.mdb
     Graphics file      :
     k_accel.gra
     Request file       :
     k_accel.req
     Results file       :
     k_accel.res
   Input Phase - Reading in Model
   ADAMS/Solver dataset Title:
   ADAMS/Car Assembly (v2005.2.0)
   Reading of model complete.
   Input Phase - Populating Solver database
---- ERROR ----
   ***** ADAMS MEMORY OVERFLOW *****
   A larger LD array is required.
   The error occurred in subroutine "LOAD_R" while allocating "CHAR" space
   for the "Routine name".
   Space Available:  0    Space Requested:  1
   ADAMS/Solver requires more program memory to run this model.
   Be aware that the above figures for Space available and Space
   requested only reflect the current requirements.  Additional space
   may be required later in the solution process.
   Several off-the-shelf memory configurations are available and
   custom configurations may be created.  The available memory models
   and the corresponding array sizes are:
        NAME      LCEXPR   LDSIZ
        STANDARD   100     2,000
        LARGE      200     2,000
        EX-LARGE   300     5,000
        HUGE      1000    50,000
   where the columns correspond to:
       LCEXPR : Maximum number of lines in a Function
       LDSIZ  : Maximum total number of lines in all Functions
   To use an alternative setting, you have to start the ADAMS 'Settings'
   program.  It can be found using the Start menu:
     Start -> Programs -> MSC.Software -> MSC.ADAMS -> ADAMS-Settings
   Terminating ADAMS/Car usersubs...
   ID = 1
      ADAMS/Solver execution terminated by subprogram LSPACE
   CPU time used = 1.2188 seconds
ERROR:  A lookup operation was still in progress when AMD was shut down.
ERROR:     Error type:  ae_lookup_unfinished
ERROR:     Parent name: .k_accel
ERROR:     Parent type: ao_model
ERROR:     Search type: ao_field
ERROR: Cannot load results!  File 'k_accel.res' not found.
ERROR: Cannot load graphics!  File 'k_accel.gra' not found.
Simulation is complete.
发表于 2007-6-8 19:41 | 显示全部楼层
好象在提醒你的运算内存不够,应改大一点.
发表于 2008-3-19 14:21 | 显示全部楼层
回复 楼主 的帖子
请楼上大哥能不能将truck模型发一份给我  小弟感激不尽
找truck模型已经找了很久  官方网站上下载不了  先谢谢大哥了
Email     liuzk113@163.com
qq      56591074
发表于 2013-10-7 22:23 | 显示全部楼层
大哥!您那有没有牵引车的模型啊 能给小弟一份不 小弟感激不尽 没齿难忘!还有 ADAMS中自带的truck整车模型能用吗 谢谢!!!
发表于 2013-10-24 22:02 | 显示全部楼层
发表于 2013-10-25 17:36 | 显示全部楼层
在Setting中把preference中的内存调成huge就可以了。
GMT+8, 2024-12-28 14:11 , Processed in 0.083870 second(s), 18 queries , Gzip On.
