查看: 2479|回复: 2
[Virtual.Lab] 那位大哥看一下哪里出问题了?谢谢
发表于 2007-6-3 10:40 | 显示全部楼层 |阅读模式
本人在ansys中建个模型:一个圆柱体和1/4个半球。划分好网格后导入到sysnoise中,分析模型上任一质点的速度和声压分布。也就是说圆柱体的一端定义一个左右摆动的力,最后求质点的速度和声压分布。在sysnoise中,长圆柱体作为结构,半球作为流体,实现结构和流体的耦合,圆柱体的具体参量:弹性模量7.4e10;泊松比0.17;密度1000
具体步骤:
1新建模型New Name 'structure' Model 1 File atructure.sdb Return
2确定分析类型Option
FEM Frequency Structure Return
3导入模型Import Mesh Format Ansys File shengxuezhuti.cdb Return
4定义材料属性Material Shell
Name 'suliao'
Young 7.4e10
Poisson 0.17
Rho 1000
Elements all
Return
5定义厚度Geometry Thickness 0.01
Elements all
Return
6建立选择集Set
1 Name
"bang "
Nodes 674 to 685 14 64 to 75
Return
7定义位移边界条件Boundary
UX Real 0 Imag 0 UY Real 0 Imag 0 UZ Real 0 Imag 0
Nodes Set 1
Return
8计算前10阶结构模态Modes
Vector 10 Tolerance 1.0000e-6 Iteration 100
BLanczos
Return
Save Return
Damping Mode 1 ETA: 0.010000 Return
Damping Mode 2 ETA: 0.010000 Return
Damping Mode 3 ETA: 0.010000 Return
Damping Mode 4 ETA: 0.010000 Return
Damping Mode 5 ETA: 0.010000 Return
Damping Mode 6 ETA: 0.010000 Return
Damping Mode 7 ETA: 0.010000 Return
Damping Mode 8 ETA: 0.010000 Return
Damping Mode 9 ETA: 0.010000 Return
Damping Mode 10 ETA: 0.010000 Return
9查看云纹图,保存模型;
10定义模态阻尼Damping Mode 1 ETA: 0.010000 Return
11定义载荷工况Boundary
FX Real 1000 Imag 0
Nodes 274
Return
12保存,新建模型New Name 'acoustic' Model 2 File acoustic.sdb Return
13确定分析类型Option
FEM Frequency Fluid Return
14导入模型Import Mesh Format Ansys File bb.cdb Return
15定义流体材料属性Material Fluid
Name 'air'
Sound Real 3.4000e+002
Rho Real 1.2250e+000
Elements all
Return
Save Return
16计算前10阶声模态Modes
BLanczos
Return
17查看声模态云纹图,保存模型;
18建立模型连接关系Link
Model 1
Elements all
To
Model 2
Faces all
Behavior FLUID-STRUCTURE
Return
19定义分析参数Parameter Model 1
Vector 10
Store Displacements none
Return
Return
Parameter Model 2
Vector 10
Save Potentials Step 1
Save Results none
Store Potentials none
Return
Store Results none
Return
NoFlow
Return
20分析求解Solve
Frequency 1 To 300 LinStep 1
Return
21提取计算结果Store
Case Active
Potentials
Nodes 274
Return
Return
22响应函数后处理
最后怎算不出结果,不知道哪里出了问题,能得到各位大哥的帮助,小弟万分感激。谢谢!!
发表于 2007-6-3 10:46 | 显示全部楼层
你的流体模型 是个曲面?
        3维的FEM应该是个体单元才对啊。
LINK 后,看看输出窗口的提示,看是否 LINK成功了。
    还有 耦合面 应该是接触的面,不是接触的面  LINK是不会成功的。
[ 本帖最后由 pengweicai 于 2007-6-3 10:50 编辑 ]
发表于 2007-6-3 15:33 | 显示全部楼层
通过这个例子,我知道了以前有个贴子提到的sysnoise是否能计算声模态的问题,这个声模态度的定义和辐射场的声模态定义是不同的,呵呵.
GMT+8, 2025-1-28 11:12 , Processed in 0.123416 second(s), 22 queries , Gzip On.
