查看: 1698|回复: 0
[综合讨论] lms算法源程序的解释
发表于 2007-6-1 14:51 | 显示全部楼层 |阅读模式
这两个算法程序看了几天都没弄明白
请帮小弟解释一下每句都是什么意思
我是初学者,麻烦了!~
%lms算法源程序
clear all
close all
%channel system order
sysorder = 5 ;
% Number of system points
N=2000;
inp = randn(N,1);
n = randn(N,1);
[b,a] = butter(2,0.25);
Gz = tf(b,a,-1);
%This function is submitted to make inverse Z-transform (Matlab central file exchange)
%The first sysorder weight value
%h=ldiv(b,a,sysorder)';
% if you use ldiv this will give h :filter weights to be
h= [0.0976;
0.2873;
0.3360;
0.2210;
0.0964;];
y = lsim(Gz,inp);
%add some noise
n = n * std(y)/(10*std(n));
d = y + n;
totallength=size(d,1);
%Take 60 points for training
N=60 ;
%begin of algorithm
w = zeros ( sysorder , 1 ) ;
for n = sysorder : N
u = inp(n:-1:n-sysorder+1) ;
y(n)= w' * u;
e(n) = d(n) - y(n) ;
% Start with big mu for speeding the convergence then slow down to reach the correct weights
if n < 20
mu=0.32;
else
mu=0.15;
w = w + mu * u * e(n) ;
%check of results
for n = N+1 : totallength
y(n) = w' * u ;
hold on
plot(d)
plot(y,'r');
title('System output') ;
xlabel('Samples')
ylabel('True and estimated output')
figure
semilogy((abs(e))) ;
title('Error curve') ;
xlabel('Samples')
ylabel('Error value')
figure
plot(h, 'k+')
hold on
plot(w, 'r*')
legend('Actual weights','Estimated weights')
title('Comparison of the actual weights and the estimated weights') ;
axis([0 6 0.05 0.35])
% RLS 算法
randn('seed', 0) ;
rand('seed', 0) ;
NoOfData = 8000 ; % Set no of data points used for training
Order = 32 ; % Set the adaptive filter order
Lambda = 0.98 ; % Set the forgetting factor
Delta = 0.001 ; % R initialized to Delta*I
x = randn(NoOfData, 1) ;% Input assumed to be white
h = rand(Order, 1) ; % System picked randomly
d = filter(h, 1, x) ; % Generate output (desired signal)
% Initialize RLS
P = Delta * eye ( Order, Order ) ;
w = zeros ( Order, 1 ) ;
% RLS Adaptation
for n = Order : NoOfData ;
u = x(n:-1:n-Order+1) ;
pi_ = u' * P ;
k = Lambda + pi_ * u ;
K = pi_'/k;
e(n) = d(n) - w' * u ;
w = w + K * e(n) ;
PPrime = K * pi_ ;
P = ( P - PPrime ) / Lambda ;
w_err(n) = norm(h - w) ;
end ;
% Plot results
figure ;
plot(20*log10(abs(e))) ;
title('Learning Curve') ;
xlabel('Iteration Number') ;
ylabel('Output Estimation Error in dB') ;
figure ;
semilogy(w_err) ;
title('Weight Estimation Error') ;
ylabel('Weight Error in dB') ;
再次感谢!~
[ 本帖最后由 eight 于 2007-6-1 15:47 编辑 ]
GMT+8, 2025-1-16 00:53 , Processed in 0.078651 second(s), 18 queries , Gzip On.
