查看: 2649|回复: 1
求救在提交作业时,出现以下错误,不知是什么原因
发表于 2007-5-24 10:50 | 显示全部楼层 |阅读模式
在提交作业时,出现以下错误,不知是什么原因?
Error in job Job-1: The executable D:\ABAQUS\6.6-1\exec\explicit.exe aborted with system error code 5. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run ABAQUS that you used when the problem occurred.  Please contact your local ABAQUS support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Job Job-1 aborted due to errors.
查看了.sta,.dat,.dat文件,没有提示有错误。
发表于 2007-5-26 10:28 | 显示全部楼层
稍微改变参数再提交一次,或直接再提交(重启电脑后)。若用子程序,先检查子程序
GMT+8, 2025-1-7 23:48 , Processed in 0.071781 second(s), 17 queries , Gzip On.
