查看: 1136|回复: 3
[综合讨论] 求:信号去噪的MATLAB程序及性能分析
发表于 2007-5-21 20:42 | 显示全部楼层 |阅读模式
我正在做毕业设计,请问谁有关信号去噪的MATLAB程序以及性能分析(信噪比、残差平方和最小、残差绝对值最小以及方差)
发表于 2007-5-22 08:48 | 显示全部楼层
这两天搞毕业设计,编的用Matlab中的fft分析含噪声的信号,其中有直接FFT,时域同步平均后FFT,频域同步平均后FFT。可以参考。
%%This procedure is to investigate the FFT of sine signal, sine signal with
%%noise.  The sine signal with noise is treated by direct FFT,
%%FFT after piece-wise averaging in time domain, and FFT after
%%piece-wise averaging  frequency domain
clear all
pack
w=10;
t=0:(2*pi/w/500):(300*2*pi/w);
x=sin(w*t);
n=length(t);
ss=888;
randn('seed',ss);
z=randn(1,n);
z1=z-mean(z);
z2=z1/max(abs(z1));
z2=z2*500;
figure(1)
plot(t,x)  % The sine signal without noise
fre=(1/(2*pi/w/500))*(1:n)/n;
nn=fix(n/2);
y1=fft(x);  % The FFT of sine signal without noise
y1=(abs(y1)).^2/n;
y2=y1(2:(nn+1));
fre1=2*pi*fre(1:nn);
figure(2)
plot(fre1,y2)
x=x+z2;
y1=fft(x);  % The FFT of sine signal with noise
y1=(abs(y1)).^2/n;
y2=y1(2:(nn+1));
figure(3)
plot(fre1,y2)         %The sine signal with noise
%% Averaging in time domain
M=10000;
xx=zeros(1,M);
m1=1;m2=M;
nnnn=fix(300*500/M);
for nnn=1:nnnn
    xxx=x(m1:m2);
    xx=xx+xxx;
    m1=m1+M;
    m2=m2+M;
fre=(1/(2*pi/w/500))*(1:M)/M;
nn=fix(M/2);
xx=xx/nnnn;
y1=fft(xx);
y1=(abs(y1)).^2/M;
y2=y1(2:(nn+1));
figure(4)
plot(fre1,y2)
% Next is averaging in frequency domain
% In fact, the averaging in time domain is identical with that in frequency
% domain
MM=10000;
xx=zeros(1,MM);
m1=1;m2=MM;
nnnn=fix(300*500/MM);
for nnn=1:nnnn
    xxx=x(m1:m2);
    xxx=fft(xxx);
    %xxx=sqrt((abs(xxx)).^2);
    xx=xx+xxx;
    m1=m1+MM;
    m2=m2+MM;
y1=xx/nnnn;
y1=(abs(y1)).^2/MM;
fre=(1/(2*pi/w/500))*(1:MM)/MM;
nn=fix(MM/2);
y2=y1(2:(nn+1));
figure(5)
plot(fre1,y2)
 楼主| 发表于 2007-5-22 20:43 | 显示全部楼层
谢谢呀!你的毕业设计是做什么的
发表于 2008-5-6 20:52 | 显示全部楼层
谢谢,我在做小波去噪,参考下
GMT+8, 2025-1-13 09:48 , Processed in 0.083585 second(s), 18 queries , Gzip On.
