查看: 1808|回复: 4
[编程技巧] 请高手看一下我的程序哪点错了,谢谢
发表于 2007-5-18 11:55 | 显示全部楼层 |阅读模式
我想用ode45解方程 那位看一下定义的函数那点错了,谢谢,小弟不胜感激
%用ode45解微分方程
该微分方程是二阶的分段函数
Fpt为分段的  程序中已定义
a_x也是分段的 也已定义
请大哥们看看程序结构上有啥错误
function d2x=BCD(t,x)
pressure=[0.00023     0         44520000     6.6
           0.00047     0.003     64770000     16.6
           0.00071     0.009     91040000     31.4
           0.00095     0.019    123450000     51.3
           0.00119     0.033    162550000     77.5
           0.00143     0.057    202360000     111.4
           0.00167     0.087    244090000     153.2
           0.00191     0.13     277710000     201.3
           0.00215     0.185    302150000     254.8
           0.00239     0.252    316080000     313.3
           0.00263     0.334    320180000     327
           0.00287     0.431    315830000     430.8
           0.00311     0.541    304200000     488.8
           0.00335     0.664    290750000     543.9
           0.00359     0.801    274550000     596.4
           0.00383     0.95     259330000     646
           0.00406     1.11     239670000     692.3
           0.0043      1.281    214310000     734.3
           0.00454     1.461    191910000     772.1
           0.00478     1.65     172380000     806
           0.00502     1.847    155630000     836.1
           0.00526     2.05     140850000     863.8
           0.0055      2.26     128050000     888.7
           0.00574     2.476    117010000     911.3
           0.00598     2.696    107180000     932.2
           0.00622     2.922     98870000     951.2
           0.00646     3.152     90980000     968.8
           0.0067      3.386     83730000     985
           0.00694     3.624     77400000     1000];
%结构参数
m_h=380;
Kr_1=1.27;
Kr_2=2;
rho=1110;
d_p=0.0242;
D_T=0.07;
d_T=0.04;
d_p=0.0242;
d_1=0.32;
A_r0=pi*(D_T^2-d_T^2)/4;
A_rp=pi*d_p^2/4;
A_fj=pi*d_1^2/4;
angle_elv=87*pi/180;
c=19527.497;                       alpha2=2.46;
f_seal=0.18;
f_track=0.3;
A_1=0.00000001;                 g=9.8;
F=f_track*m_h*g;
F_T=f_seal*m_h*g*cos(angle_elv); %
F_f0=alpha2*m_h*g;
%参数
m_y=1.2;
m_q=2.8;
m_h=380;
phi=1.1729;
phi_1=1.02;                         %.........................................................................
area_bore=0.00266;                  beta=1.3;                           beta_T=0.5276;                      eta_brake=0.38;
b_time=0.0047;
t_tau= 0.0286;                      Fpt_g=2.1667e+005;
t_g=0.00694;
[n1,n2]=size(pressure);
%流液孔的面积
if x<=0.035
    d_x=0.019;
    a_x=pi*(d_p^2-d_x^2)/4;
  elseif x<=0.225
     d_x=0.019+((21.6-19)/(225-35))*(x-0.035);
     elseif x<=0.3
     d_x=0.0216+((22.6-21.6)/(300-225))*(x-0.225);
     elseif x<=0.34
     d_x=0.0226+((23.3-22.6)/(340-300))*(x-0.3);
     elseif x<=0.36
     d_x=0.0233+((24.2-23.3)/(360-340))*(x-0.34);
  else
    d_x=0.0242;
if t<=t_g                                             %
  Fpt_i=(1+0.5*(m_y/m_q))*area_bore*pressure(:,3)/phi;
  Fpt=lagr_interp12(pressure(:,1),Fpt_i,t);
elseif t<=t_g + t_tau                                  %
  chi=((m_q+beta*m_y)*sqrt(1.0-eta_brake)-(m_q+0.5*m_y)) ...
      /((beta-0.5)*m_y);
  Fpt=chi*Fpt_g*exp(-(t-t_g)/b_time);
else                                                    %
  Fpt=0.0;
F_cR=m_h*9.8*(f_seal+f_track*cos(angle_elv)-sin(angle_elv));  %  计算后坐阻力常数项
F_phi=(1/2)*(rho*Kr_1*(A_r0-A_rp)^3/(a_x.^2)+rho*Kr_2*(A_fj^3)/(A_1^2));
% we let x(1)=x and x(2)=x',then x(1)'=x(2)
% and x(2)'=(1/2)*380*(Fpt-(F_phi*(x(2)^2)+F_f0+c*x(1)+F_cR))
d2x=[x(2);(1/2)*380*(Fpt-(F_phi*(x(2)^2)+F_f0+c*x(1)+F_cR))]; 所用公式说明.doc (39 KB, 下载次数: 8)
[ 本帖最后由 lyy525525 于 2007-5-18 12:12 编辑 ]
发表于 2007-5-18 18:20 | 显示全部楼层
原帖由 lyy525525 于 2007-5-18 11:55 发表
%用ode45解微分方程
该微分方程是二阶的分段函数
Fpt为分段的  程序中已定义
a_x也是分段的 也已定义
请大哥们看看程序结构上有啥 ...
请按照 置顶贴:聚宝盆 的要求把你的问题叙述清楚
发表于 2007-5-18 19:40 | 显示全部楼层
建议将主命令及出错信息先给出.
 楼主| 发表于 2007-5-18 20:05 | 显示全部楼层
主命令是
主命令是
tspan=[0 0.00694];
x0=[0;0];
[x,y]=ode45('BCD',tspan,x0)
 楼主| 发表于 2007-5-18 20:12 | 显示全部楼层
错误是
错误是一直在运行,一直显示busy
该函数能用ode45解吗?
函数描述:二阶的隐性微分方程
微分方程中嵌套着两个分段函数
能解的话,该函数怎么定义,谢谢各位高手
[ 本帖最后由 eight 于 2007-5-18 20:25 编辑 ]
GMT+8, 2025-1-16 05:35 , Processed in 0.070119 second(s), 22 queries , Gzip On.
