查看: 1302|回复: 2
求助各位大虾!
发表于 2007-5-17 10:22 | 显示全部楼层 |阅读模式
用SIMULINK建模之后运行在MATLAB窗口出现如下提示是什么意思?
Derivative input 1 of 'meanvaluemodle/manifold air mass flow/Integrator' at time 0 is Inf or NaN.
Warning: Division by zero in 'meanvaluemodle/Math Function'.
Warning: Division by zero in 'meanvaluemodle/manifold air mass flow/Math Function'.
Warning: Division by zero in 'meanvaluemodle/manifold air mass flow/Fcn3'.
Warning: Division by zero in 'meanvaluemodle/crank shaft and loading/Math Function1'.
Warning: Result of power is undefined in 'meanvaluemodle/crank shaft and loading/Subsystem3/Math Function2'.
发表于 2007-5-17 15:44 | 显示全部楼层
你的模块里面有被0除的情况,当然该情况一般都是在开始启动的情况
请在你有除0情况的分母加个1e-3或者-4样子就可以了.
 楼主| 发表于 2007-5-18 11:50 | 显示全部楼层
谢谢
GMT+8, 2025-2-20 23:05 , Processed in 0.091681 second(s), 17 queries , Gzip On.
