查看: 5564|回复: 22
[HHT] 转网上的一个简单直观的EMD程序,有助初学理解
发表于 2007-5-16 11:54 | 显示全部楼层 |阅读模式
呵呵,可能大家都有了这个程序了,不过我觉得这个程序对我现在刚学EMD很有帮助,
因为程序简单,太长了初学的时候没有耐心看那么多行的程序
我根据我的理解对程序作了一些简单的注释,EMD原理基本理解,但是对于程序具体实现时有些地方不太懂,欢迎大家指正,共同探讨。
这个程序是一个最基本的程序,没有包括任何改进算法,如端点延拓等。
% EMD:  Emprical mode decomposition
% imf = emd(x,n)
% x   - input signal (must be a column vector)
% n   - number of intrinsic mode functions
% imf - Matrix of intrinsic mode functions (each as a row)
% See:  Huang et al, Royal Society Proceedings on Math, Physical,
%       and Engineering Sciences, vol. 454, no. 1971, pp. 903-995,
%       8 March 1998
% Author: Ivan Magrin-Chagnolleau  <ivan@ieee.org>
function imf = emd(x,n);%%最好把函数名改为emd1之类的,以免和Grilling的emd冲突
                                  %%n为你想得到的IMF的个数
c = x(:)'; % copy of the input signal (as a row vector)
N = length(x);-
% loop to decompose the input signal into n successive IMFs
imf = []; % Matrix which will contain the successive IMF, and the residuefor t=1:n
% loop on successive IMFs
% inner loop to find each imf
h = c; % at the beginning of the sifting process, h is the signal
SD = 1; % Standard deviation which will be used to stop the sifting process
while SD > 0.3 % while the standard deviation is higher than 0.3 (typical value) %%筛选停止准则
% find local max/min points
d = diff(h); % approximate derivative %%求各点导数
maxmin = []; % to store the optima (min and max without distinction so far)
for i=1:N-2
  if d(i)==0                        % we are on a zero %%导数为0的点,即”驻点“,但驻点不一定都是极值点,如y=x^3的x=0处
        if sign(d(i-1))~=sign(d(i+1))  % it is a maximum %%如果驻点两侧的导数异号(如一边正,一边负),那么该点为极值点
        maxmin = [maxmin, i];                         %%找到极值点在信号中的坐标(不分极大值和极小值点)
  elseif sign(d(i))~=sign(d(i+1))   % we are straddling a zero so%%如y=|x|在x=0处是极值点,但该点倒数不存在,所以不能用上面的判
        断方法
   maxmin = [maxmin, i+1];        % define zero as at i+1 (not i) %%这里提供了另一类极值点的判断方法
if size(maxmin,2) < 2 % then it is the residue %%判断信号是不是已经符合残余分量定义
break
% divide maxmin into maxes and mins  %% 分离极大值点和极小值点
if maxmin(1)>maxmin(2)              % first one is a max not a min
maxes = maxmin(1:2:length(maxmin));
mins  = maxmin(2:2:length(maxmin));
else                                % is the other way around
  maxes = maxmin(2:2:length(maxmin));
  mins  = maxmin(1:2:length(maxmin));
end            % make endpoints both maxes and mins
maxes = [1 maxes N];
mins  = [1 mins  N];
%-------------------------------------------------------------------------      % spline interpolate to get max and min envelopes; form imf
  maxenv = spline(maxes,h(maxes),1:N);    %%用样条函数插值拟合所有的极大值点
minenv = spline(mins, h(mins),1:N);     %%用样条函数插值拟合所有的极小值点
m = (maxenv + minenv)/2; % mean of max and min enveloppes  %%求上下包络的均值
prevh = h; % copy of the previous value of h before modifying it %%h为分解前的信号
h = h - m; % substract mean to h                         %% 减去包络均值
% calculate standard deviation
eps = 0.0000001; % to avoid zero values
SD = sum ( ((prevh - h).^2) ./ (prevh.^2 + eps) );         %% 计算停止准则
imf = [imf; h]; % store the extracted IMF in the matrix imf
% if size(maxmin,2)<2, then h is the residue
% stop criterion of the algo. if we reach the end before n
break
c = c - h; % substract the extracted IMF from the signal
return
[ 本帖最后由 zhlong 于 2007-5-16 12:01 编辑 ]
 楼主| 发表于 2007-5-16 12:08 | 显示全部楼层
t=[0:0.0001:(0.0512-0.0001)];
a=16;
x=sin(2*pi*(200*t))+sin(2*pi*(500*t));
分别利用上面的程序(令n=2)和Flandrin的程序得到的结果如图11和22所示
发表于 2007-5-16 20:04 | 显示全部楼层
多谢zhong:handshake ,不过还得请教一下,Flandrin的程序是什么,
能说详细点么,小弟刚开始学,多谢啦!!!!!!!!!!!!!
发表于 2007-5-16 20:06 | 显示全部楼层
回复 #3 ytlzd 的帖子
你为什么对这么多置顶贴视若无睹,我们的努力白费了!:@Q
发表于 2007-5-28 07:39 | 显示全部楼层
补一个和楼主出处在一起的EMD程序另一种写法:这两个程序的源应该是美国rice大学.
注解我就不加了,和楼主的有很多是一样的.大家看看吧
% imf = emd(x)
% This version will calculate all the imf's (longer)
%       with residual in last row.
%       8 March 1998
function imf = emd(x);
N = length(x);
% loop to decompose the input signal into successive IMF
while (1) % the stop criterion is tested at the end of the loop
   while SD > 0.3
      for i=1:N-2
         break
      mins  = [1 mins  N];
      break
return
发表于 2007-7-30 15:02 | 显示全部楼层
比较了zhlong给的程序,qinle的多一个while(1)语句,我运行后者,发现matlab死循环,不知道是否这个原因,这个while语句到底如何解释呢?:@Q
发表于 2007-9-2 17:28 | 显示全部楼层
能否解释以下if size(maxmin,2) < 2  中括弧中的2是什么意思?
发表于 2007-9-2 19:16 | 显示全部楼层
看了程序,以下问题有点不解:
(1) c = x(:)'这样等于c=x,并不是c=x',不知道编程的者的意图是什么?
(2)imf=emd(x,n)中imf的个数n在程序中那里有体现?
(3)size(maxmin,2)还有这个2是什么意思呀?
[ 本帖最后由 kevin19821 于 2007-9-2 20:05 编辑 ]
发表于 2007-9-2 20:00 | 显示全部楼层
不错,对初学者很有帮助!我有个问题?
对于下面这条语句中的"n为你想得到的IMF的个数"这句话中n是在运行程序前设定好的吗?根据设想随便定的吗?不是emd自己分解出几个imf就是几个吗?
                                  %%n为你想得到的IMF的个数
发表于 2007-9-2 20:07 | 显示全部楼层
同意楼上的,
发表于 2007-9-2 21:08 | 显示全部楼层
原帖由 jingrenzhi 于 2007-9-2 20:00 发表
不错,对初学者很有帮助!我有个问题?
function imf = emd(x,n);%% ...
可以让它自己分解,最终得到的个数不定;也可以提供用户自己设定,分解到满足用户指定的个数后就终止,剩下的全部作为余量
发表于 2007-9-2 22:06 | 显示全部楼层
回复 #11 eight 的帖子
哦,是这样!谢谢!那么"如果分解到满足用户指定的个数后就终止,剩下的全部作为余量"的话,楼主的这句程序是不是应该写成
function imf = emd(x);  ?
如5楼的程序!
发表于 2007-9-2 23:13 | 显示全部楼层
原帖由 jingrenzhi 于 2007-9-2 22:06 发表
如5楼的程序!
function imf = emd(x) 这是默认的分解方式,分解的个数不定
function imf = emd(x,n) 这是提供用户自定义的方式
发表于 2007-9-3 16:35 | 显示全部楼层
我自己用楼主程序加曲线延拓后所得的IMF和RES图如下:
晕!图片太大,发不上来
[ 本帖最后由 kevin19821 于 2007-9-3 16:44 编辑 ]
发表于 2007-9-3 16:48 | 显示全部楼层
回复 #13 eight 的帖子
哦!明白!谢谢!
GMT+8, 2025-1-9 00:00 , Processed in 0.100935 second(s), 25 queries , Gzip On.
