查看: 1083|回复: 3
[编程技巧] 请各位帮忙看一下这个程序
发表于 2007-5-13 22:39 | 显示全部楼层 |阅读模式
function recognize = my_pca(path,persons,numface,numtrain,numpc)
path='D:\ORLface\';
persons=2;
numface=5;
numtrain=3;
numpc=15;
rbf_var=0.1;
for i=1:persons
    str=num2str(i);
    if i<10
        str=['0',str];
    Folder(i,:)=[path,'s',str,'\'];
BMPfile =['01.bmp';'02.bmp';'03.bmp'];
for i=1:persons
   for j=1:numtrain
     img_name=[Folder(i,:),BMPfile(j,:)];
     img=double(imread(img_name));
     if i==1 & j==1
         size_img=size(img);
         Dim=size_img(1)*size_img(2);
     img=reshape(img,Dim,1);
     X(:,numtrain*(i-1)+j)=img;
all_train=persons*numtrain;
     eface=zeros(Dim,1);
     for i=1:all_train
         eface=eface+X(:,i);
     eface=eface/all_train;
for i=1:all_train
    X(:,i)=X(:,i)-eface;
[X1,X2]=wavedec2(X,1,'haar');
Xa=appcoef2(X1,X2,'haar',1);
for i=1:all_train,
  for j=i:all_train,
    Xa(i,j) = exp(-norm(X(:,i)-X(:,j))^2/rbf_var);
    Xa(j,i) = Xa(i,j);
unita=ones(all_train,all_train)/all_train;
Xcal=Xa-unita*Xa-Xa*unita+unita*Xa*unita;
[V,D]=eig(Xa);
D=real(diag(D));
for i=1:all_train,
  V(:,i)=V(:,i)/(sqrt(D(i)));
Features_Xcal=zeros(all_train,numpc);
Features_Xcal=Xcal*V(:,1:numpc);
numtest=numface-numtrain;
for i=1:persons
   for j=(numtrain+1):numface
     Y(:,numtest*(i-1)+(j-numtrain))=img;
all_test=persons*numtest;
for i=1:all_test
     Y(:,i)=Y(:,i)-eface;
[Y1,Y2]=wavedec2(Y,1,'haar');
Ya=appcoef2(Y1,Y2,'haar',1);
unitb=ones(all_test,all_train)/all_train;
Ya=zeros(all_test,all_train);
for i=1:all_test,
  for j=1:all_train,
    Ya(i,j)=exp(-norm(Y(:,i)-X(:,j))^2/rbf_var);
Ycal=Ya-unitb*Xa-Ya*unita+unitb*Xa*unita;
Features_Ycal=zeros(all_test,numpc);
Features_Ycal=Ycal*V(:,1:numpc);
err=0;
Xclass=zeros(all_train,1);
Yclass=zeros(all_test,1);
Yresult=zeros(all_test,1);
for xc=1:all_train
    Xclass(ac)=ceil(ac/numtrain);
for yc=1:all_test
    Yclass(bc)=ceil(bc/numtest);
for i=1:all_test
    Dij=zeros(all_train,1);
    for j=1:all_train
        FD=Feature_Ycal(:,i)-Feature_Xcal(:,j);
        Dij(j)=norm(FD);
    [Min,IND]=sort(Dij);
    Yresult(i)=Xclass(IND(1));
    if Yresult(i)~=Yclass(i)
        err=err+1;
recognize=['正确识别率:',num2str((1-err/all_test)*100),'%']
请各位帮忙看一下为什么运行不了,急~~谢谢了
Untitledca.m
2.65 KB, 下载次数: 9
发表于 2007-5-14 00:18 | 显示全部楼层
原帖由 9clock 于 2007-5-13 22:39 发表
path='D:\ORLface\';
persons=2;
numface=5;
numtrain=3;
numpc=15;
rbf_var=0.1;
for i=1:persons
    str=num2str(i);
    if i
请参照置顶贴:聚宝盆把你的问题叙述清楚,特别是给出出错信息!
 楼主| 发表于 2007-5-14 13:53 | 显示全部楼层
不好意思 这是显示的错误信息
??? Index exceeds matrix dimensions.
On line 52  ==> Xcal=Xa-unita*Xa-Xa*unita+unita*Xa*unita
这程序是个kpca的人脸识别程序,但是我在核函数运算(将数据由低维转到高维)部分不是很清楚,for i=1:all_train,
  for j=i:all_train,
    Xa(j,i) = Xa(i,j);
end(这个部分)
所以设计可能有错,请各位多多帮助一下,谢谢了
发表于 2007-5-14 15:05 | 显示全部楼层
原帖由 9clock 于 2007-5-14 13:53 发表
不好意思 这是显示的错误信息
这程序是个kpca的人脸识别程序,但是我在核函数运算(将数据由低维转 ...
访问越界,这种问题自己根据出错提示的位置设置断点,然后调试一下就可以了
GMT+8, 2025-1-31 01:03 , Processed in 0.121358 second(s), 21 queries , Gzip On.
