查看: 1489|回复: 11
求助:出现错误
发表于 2007-5-4 14:46 | 显示全部楼层 |阅读模式
错误是:Output returned by S-function 'chap_1s' in block 'chap10_1/S-Function' during flag=3 call must be a real vector of length 1
S函数控制程序是:chap_1s.m
function[sys,x0,str,ts] = spacemodel(t,x,u,flag)
switch flag,
    case 0,
       [sys,x0,str,ts]=mdlInitializeSizes;
    case 3,
        sys=mdlOutputs(t,x,u);
    case{2,4,9}
        sys=[];
    otherwise
        error(['Unhandled flag = ',num2str(flag)]);
function [sys,x0,str,ts] = mdlInitializeSizes
sizes = simsizes;
sizes.NumContStates = 0;
sizes.NumDiscStates = 0;
sizes.NumOutputs    = 1;
sizes.NumInputs     = 3;
sizes.DirFeedthrough = 0;
sizes.NumSampleTimes =1; % At least one sample time is needed
sys = simsizes(sizes);
x0 = [];
str = [];
ts = [0 0];
function sys=mdlOutputs(t,x,u)
g=9.8;
m=1;
l=0.25;
d=2.0;
a=20.0;b=15.0;
I=4/3*m*l^2;
A=1.0;F=1.0;
r=u(1);
x1=u(2);
x2=u(3);
dr=A*F*2*pi*cos(F*2*pi*t);
ddr=-A*(F*2*pi)^2*sin(2*pi*t);
e=x1-r;
de=x2-dr;
tol=(d-a*I)*de-b*I*e+I*ddr+d*dr+m*g*l*cos(x1);
sys(1)=tol;
S函数被控制程序是:chap_1plant.m
switch flag,
    case 0,
    case 1,
        sys=mdlDerivatives(t,x,u);
    case 3,
    case{2,4,9}
        sys=[];
    otherwise
function[sys,x0,str,ts] = mdlInitializeSizes
sizes = simsizes;
sizes.NumContStates =2;
sizes.NumDiscStates =0;
sizes.NumOutputs    =2;
sizes.NumInputs    =1;
sizes.DirFeedthrough =0;
x0 = [0;0];
str = [];
ts = [0 0];
function sys=mdlDerivatives(t,x,u)
g=9.8;
m=1;
l=0.25;
d=2.0;
I=4/3*m*l^2;
tol=u;
sys(1)=x(2);
sys(2)=1/I*(-d*x(2)-m*g*l*cos(x(1))+tol);
sys(1)=x(1);
sys(2)=x(2);
模型如下:
[ 本帖最后由 xinyuxf 于 2007-5-4 19:42 编辑 ]
chap10_1.mdl
12.69 KB, 下载次数: 6
发表于 2007-5-4 17:37 | 显示全部楼层
回复 #1 034100643 的帖子
将chap_1s.m
当中的初始化中Dirreedthrough设置为1好像可以仿真,但是不知道结果是不是对的,你试试
 楼主| 发表于 2007-5-4 18:15 | 显示全部楼层
作图程序出问题了
我按你说了试了,刚才的错误是不见了.但是作图程序出错,错误是??? Error using ==> plot
Data may not have more than 2 dimensions.,作图程序如下:
>>close all;
>> figure(1);
>> plot(t,e,'r');
>>xlable('time(s)');yable('error');
感觉是向量矩阵前后不符合!!
发表于 2007-5-4 19:10 | 显示全部楼层
回复 #3 034100643 的帖子
你的作图程序是单独的吗
 楼主| 发表于 2007-5-4 19:18 | 显示全部楼层
不是!是和这个模型一起的,其实这些程序我是照<<先进PID控制>>这本书上原样写下来的,是一个确定性机械手的PD+前馈控制,但是就是调试没有通过.刚才的作图只是其中一个关于误差的,还有几个对应于几个WORKSPACE的.有点心急!!希望能再解答下!!
发表于 2007-5-4 19:29 | 显示全部楼层
回复 #5 034100643 的帖子
你输出的t是仿真时间,e是什么啊?是刚才输出的变量吗
 楼主| 发表于 2007-5-4 19:33 | 显示全部楼层
e是输出误差,,y是正弦位置跟踪,dy是正弦速度跟踪,而tol是控制器输出.要不你加我QQ一起谈下,希望你能指点我一下,这样稍微有点不方便:handshake .
 楼主| 发表于 2007-5-4 19:34 | 显示全部楼层
QQ271638963
QQ是271638963
发表于 2007-5-4 19:47 | 显示全部楼层
回复 #8 034100643 的帖子
你可以设置程序使之输出e的值,看看输出的情况和你要求的是不是一样
 楼主| 发表于 2007-5-4 19:54 | 显示全部楼层
e已经是一个输出值了啊!!在模型最后面的workspace中就包括e啊,就表示是输出误差.可能因为我是菜鸟,请你稍微讲的详细点.我感觉这里不是输出的问题,感觉是向量问题,就是找不到具体原因.
发表于 2007-5-4 20:33 | 显示全部楼层
回复 #10 034100643 的帖子
是啊,但是你要看输出是不是合理的啊,我的模型有时候也可以跑,但是输出的是NaN,所以这个时候需要看看你的输出的值的情况啊
 楼主| 发表于 2007-5-5 18:27 | 显示全部楼层
e的值感觉不对,误差出现了负值,其他模型方面就e这个跟踪误差是错误的!!希望高手指点帮忙下!!!
GMT+8, 2024-11-29 10:11 , Processed in 0.063819 second(s), 22 queries , Gzip On.
