查看: 2697|回复: 5
[前处理] 运行gambit时出错~请高手点拨
发表于 2007-5-4 09:34 | 显示全部楼层 |阅读模式
Locating Exceed installation ...
gambit failed in locating Exceed installation on your system.
Please try to start Exceed manually before you run gambit.
Starting C:\Fluent.Inc\gambit2.3.16\ntx86\gambit.exe -device open -id default_id3516 -new  ...
Gambit build SP2006032921.
Warning : The current transport does not permit the attempted TCPIP connection.
TRANS(SocketINETGetAddr): tnamebysocket() failed
TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed
TRANS(Open): transport open failed for tcp/dyq:0
Unable to open display
版本exceed6.2    gambit2.3.16     fluent2.1.22
发表于 2007-5-5 14:51 | 显示全部楼层
你可看看你所用的exceed 版本是否适用于gambit
发表于 2007-5-5 18:44 | 显示全部楼层
刚开始我装的是EXCEED.V7.1   gmbit2.3.16     fluent2.1.22
后来从装了是EXCEED.V10 可用
 楼主| 发表于 2007-5-9 13:40 | 显示全部楼层
换了一个EXCEED版本,问题解决了~~~谢谢各位:lol
发表于 2011-10-9 12:12 | 显示全部楼层
我安装gambit也出现和你一样的问题 请问你是怎么解决的??
我的邮箱 shilei2002yoda@163.com
发表于 2011-10-20 10:43 | 显示全部楼层
GMT+8, 2024-12-3 10:53 , Processed in 0.125593 second(s), 18 queries , Gzip On.
