查看: 839|回复: 0
[编程技巧] 求助:帮忙解读程序!
发表于 2007-4-25 22:05 | 显示全部楼层 |阅读模式
我是一个初学者,在理解这个程序时遇到了一些麻烦,烦请各位帮帮忙,帮我讲解一下这个程序的算法!谢谢各位!
function [p,f] = filtbank(x,Fs,T,arg4);
% FILTBANK One-third-octave band frequency analyser.
%    [P,F] = FILTBANK(X,Fs) computes the one-third-octave spectrum
%    of X, assuming sampling frequency Fs (in Hz). P is a row vector
%    containing RMS powers computed for each 1/3-octave band and expressed
%    in dB with 1 as reference level. F contains the corresponding preferred
%    labeling frequencies (standard ANSI S1.6-1984).
%    Plots can be obtained, e.g., with BANKDISP.
%    Example: (spectrum of white noise)
%               X = rand(1,100000);
%                [P,F] = filtbank(X,44100);
%                 bankdisp(P,F,-40,-20);
%    The frequency range covered is the standard 'restricted' audio range:
%    from 100 Hz to 5000 Hz.
%    [P,F] = FILTBANK(X,Fs,T) computes a sequence of one-third-octave
%    spectra with integration time T (in s). P is a matrix of size
%    (LENGTH(X)/(T*Fs)) x LENGTH(F). If T = [] (default), the integration
%    time is equal to the length of X.
%    [P,F] = FILTBANK(X,Fs,T,'extended') covers the 'extended' audio range:
%    from 25 Hz to 20 000 Hz. Note that depending on the value of Fs
%    the frequency range might be automatically reduced. Warnings will be
%    issued if this is the case.
%    See also BANKDISP, LEQ.
if (nargin < 2) | (nargin > 4)
   error('Invalid number of arguments');
pi = 3.14159265358979;
Fref = [ 25 31.5 40, 50 63 80, 100 125 160, 200 250 315, 400 500 630, ...
         800 1000 1250, 1600 2000 2500, 3150 4000 5000, 6300 8000 10000, ...
         12500 16000 20000 ];             % Preferred labeling freq.
Fc = 1000*((2^(1/3)).^[-16:1:13]);        % Exact center freq.
N = 3;                                    % Order of analysis filters.
extended = 0;
U = 2^(1/3);
% Integration time.
if (nargin>=3)
  if isempty(T)
    T = length(x);
    P = zeros(1,length(Fref));
  else                                         % Convert T to number of samples.
    T = floor(Fs*T);
    P = zeros(floor(length(x)/T),length(Fref));
else
    T = length(x);
if (nargin >= 4)
  if strcmp(lower(arg4),'extended')  % Extended (25 Hz to 20000 Hz)
      extended = 1;
% Frequency range.
if (extended)                                 % extended (25 Hz to 20 000 Hz).
  i_up = 30;
  i_low = 1;
else                                         % restricted (100 Hz to 5000 Hz).
  i_up = 24;
  i_low = 7;
% Check sampling frequencies and issue warnings.
if (Fs/2) < Fref(i_low)*1.5
  error('Sampling frequency Fs too low.');
elseif (Fs/2) < Fref(i_up)*1.5
  disp('Warning: frequency range must be reduced (Fs too low).');
  i_up = max(find(Fc<=Fs/3));
% Compute 'pivot' frequency for multirate filter implementation
% All filters below Fs/20 will be implemented after a decimation.
if (Fc(i_low) > Fs/20)
  i_dec = 0;
else
  i_dec = max(find(Fc<=Fs/20));
% Design filters and compute RMS powers in 1/3-oct. bands.
% Higher frequencies, direct implementation of filters.
for i = i_up:-1:i_dec+1
  [B,A] = oct3dsgn(Fc(i),Fs,N);
  y = filter(B,A,x);
  P(:,i) = leq(y,T);
% Lower frequencies, decimation by series of 3 bands.
if (i_dec > 0)
  [Bu,Au] = oct3dsgn(Fc(i_dec),Fs/2,N); % Upper 1/3-oct. band in last octave.
  [Bc,Ac] = oct3dsgn(Fc(i_dec)/U,Fs/2,N); % Center 1/3-oct. band in last octave.
  [Bl,Al] = oct3dsgn(Fc(i_dec)/(U^2),Fs/2,N); % Lower 1/3-oct. band in last octave.
  i = i_dec;
  while  i >= i_low+2
     x = decimate(x,2);
     T = T/2;
     y = filter(Bu,Au,x);
     P(:,i) =  leq(y,T);
     y = filter(Bc,Ac,x);
     P(:,i-1) =  leq(y,T);
     y = filter(Bl,Al,x);
     P(:,i-2) =  leq(y,T);
     i = i-3;
  if (i == (i_low+1))
     x = decimate(x,2);
     T = T/2;
     P(:,i) =  leq(y,T);
  elseif (i == (i_low))
     x = decimate(x,2);
     T = T/2;
     P(:,i) =  leq(y,T);
f = Fref(i_low:i_up);
p = P(:,i_low:i_up);
GMT+8, 2025-1-30 14:21 , Processed in 0.098978 second(s), 18 queries , Gzip On.
