查看: 1770|回复: 1
[HHT] local_emd.m中代码请教 ^_^
发表于 2007-4-6 10:50 | 显示全部楼层 |阅读模式
在G.Rilling local_emd.m中,下面这段代码怎么读不懂啊,烦请高人给点拨一二……
    Q:
        1. 此段代码在此任何用意(“ON EMPIRICAL MODE DECOMPOSITION AND ITS ALGORITHMS”中似乎并未说明);
        2. 另外程序在 line155 中出现了一个 'j' 却也不知作何用?/ line163中的'num2str(s)' 中的 ‘s’也不知从何而来;
        3. 这部分代码对整个EMD分解会不会有较大影响?
    谢谢!!!:@)
    % definition of f equal to 1 where sifting is needed and
    % decays fast to 0 in the neighbourhood
    badsx = (sx > sd & amp > mamp/20) | (sx > sd2 & amp > mamp/100);
    d = diff([0 badsx 0]);
    debs = find(d==1);
    fins = find(d==-1)-1;
    if length(debs)~=length(fins)
      error('pb avec le regroupement en composantes connexes')
    indextr = sort([indmin indmax]);
    d = diff(indextr);
    f = [];
    connexe = [];
    lc = length(debs);
    if lc > 0
      connexe(lc,lx) = 0;
      for i = 1:lc
        connexe(i,debs(i):fins(i)) = 1;
    % indices of previous and next extrema
    indp = min([nem-1,length(find(indextr < debs(i)))]);
        inds = max([2,length(find(indextr <= fins(i)))+1]);
    % evaluation of extrema densities left and right
        llarg = mean(d(min([nem-1,max([1,indp])]):max([1,min([nem-1,indp + 2])])));
        rlarg = mean(d(min([nem-1,max([1,inds - 1])]):max([1,min([nem-1,inds + 1])])));
    larg = mean([rlarg,llarg]);
    % special cases...
    if indp == 0
          if inds ~= (nem+1)
            larg = (indextr(inds)-indextr(inds-1));
          else
            larg = round(lx/2);
        else
          if  inds ~= (nem+1)
            larg = max([(indextr(inds)-indextr(inds-1)),(indextr(indp+1)-indextr(indp))]);
          else
            larg =(indextr(indp+1)-indextr(indp));
        larg = 2*max([round((fins(i)-debs(i))/4),larg,LARGMIN]);
    w(1:round(larg/2)) = [1:round(larg/2)]/round(larg/2);
        w((2*larg+2-round(larg/2)):(2*larg+1)) = fliplr(w(1:round(larg/2)));
        w(round(larg/2):(2*larg+2-round(larg/2))) = 1;
        indd = max(1,debs(i)-larg);
        indf = min(lx,fins(i)+larg);
        connexe(i,indd:debs(i)) = w((larg+1-debs(i)+indd):(larg+1));
        connexe(i,fins(i):indf) = w((larg+1):(larg+1+indf-fins(i)));
      f = max(connexe,[],1);
    else
      f(lx) = 0;
    m = m - f.*envmoy;
    [indmin,indmax,indzer] = extr(m);
    lm=length(indmin);
    lM=length(indmax);
    nem = lm + lM;
    nzm = length(indzer);
 楼主| 发表于 2007-4-6 22:08 | 显示全部楼层
看来大家都很忙啊,还望有时间的时候给解释一下……:@) :@) :@)
GMT+8, 2025-1-27 09:46 , Processed in 0.100397 second(s), 17 queries , Gzip On.
