查看: 3886|回复: 3
[编程技巧] 求助:newff语句的使用问题
发表于 2007-3-28 13:47 | 显示全部楼层 |阅读模式
用newff建立BP网络的时候,如果用trainlm方法,即
net=newff([0 1;0 1;0 1;0 1;0 1;0 1;0 1;0 1;0 1],[9 6 2],{'tansig','logsig','purelin'},'trainlm');
是可以定义的,
可是如果把trainlm改为traingd,即
net=newff([0 1;0 1;0 1;0 1;0 1;0 1;0 1;0 1;0 1],[9 6 2],{'tansig','logsig','purelin'},'traingd');
则会产生错误,如下所示
Warning: feval on script names will not work, or may work differently,
in a future version of MATLAB. To make your code insensitive to any change
and to suppress this warning message:
- Either change the script to a function.
- Or use eval instead of feval.
The script file in question is traingd.
> In network.subsasgn>setTrainFcn at 1459
In network.subsasgn at 405
In newff at 160
??? Attempt to execute SCRIPT traingd as a function.
Error in ==> network.subsasgn>setTrainFcn at 1459
net.trainParam = feval(trainFcn,'pdefaults');
Error in ==> network.subsasgn at 405
  [net,err]=setTrainFcn(net,trainFcn);
Error in ==> newff at 160
net.trainfcn = btf;
请问这是什么原因?
发表于 2007-3-28 15:11 | 显示全部楼层
原帖由 veronicahan 于 2007-3-28 13:47 发表
net=newff(,,{'tansig','logsig','purelin'},'trainlm');
是可以定义的,
net=newff(,,{'tansig','logsig','purelin'},' ...
我运行了一下,没有问题,请保证所用的 newff 函数是matlab默认的,有疑问请看帖子:“写给学习matlab的新手们”
发表于 2008-11-6 16:36 | 显示全部楼层
我也运行了一下,没有问题
发表于 2008-11-6 17:07 | 显示全部楼层
是不是你把函数给代用啦
GMT+8, 2025-1-12 18:04 , Processed in 0.059144 second(s), 18 queries , Gzip On.
