查看: 2205|回复: 5
请问各位有没有关于冲击测量的资料呢?谢谢
发表于 2007-3-19 15:17 | 显示全部楼层 |阅读模式
发表于 2007-3-19 17:13 | 显示全部楼层
回复 #1 hhbww163 的帖子
冲击传感器倒是有的,冲击资料网上能找到。
 楼主| 发表于 2007-3-19 17:19 | 显示全部楼层
我搜了一圈,只看见有冲击测量仪啊,之类的.有关于这个仪器的指标什么的.我想要冲击测量的原理和大概怎么实现冲击测量功能的资料.请问那位有呢?
 楼主| 发表于 2007-3-20 11:35 | 显示全部楼层
没希望了. :'(
发表于 2007-3-20 13:15 | 显示全部楼层
  我们公司有冲击测量分析系统,请关注www.econ-group.com,你可以在我们网站上找到你需要的技术参数!
ST
Shock Test System
Unique Shock Measurement Tester in the World
Overview
ST series Shock test system is a unique shock measurement tester in the world, which can meet the most rigorous criterions in the world. With SRS analysis, ST can fulfill the measurement requirements in applications such as: Shock/Drop/Crash testing, Shock waveform transient capture and SRS analysis, Shock test control, etc.
Features
•  Meet JJG, ISO, MIL-STD-810 and DELL criterions.
•  Sampling frequency: up to 1MHz.
    Acceleration range: up to 100,000gn.
•  With shock response spectrum (SRS) analysis.
•  Pass/fail Verification analysis.
•  Transient waveform Recall and exploring
•  Automatic test report generation.
Specifications
•  2, 4 input channels, built-in ICP sensor power.
•  Sampling frequency: 192KHz, 1MHz.
•  ADC resolution: 24-bit.
•  Acceleration range: up to 100,000gn.
•  Pulse duration: 0.1ms~5,000ms.
•  Waveform control, 1/24th SRS analysis.
 楼主| 发表于 2007-3-20 13:32 | 显示全部楼层
谢谢了.终于看见希望了.
GMT+8, 2025-1-26 09:12 , Processed in 0.081539 second(s), 17 queries , Gzip On.
