查看: 2910|回复: 5
[其他相关] 求助--关于压电陶瓷分析
发表于 2005-10-17 16:33 | 显示全部楼层 |阅读模式
   请问谁有关于压电陶瓷分析的实例,查遍了很多书都没有找到,请高手不吝赐教。
  还有请问压电陶瓷的参数怎么设置?极化方向怎么设置呢?
发表于 2005-10-17 17:07 | 显示全部楼层
回复:(eaglerna)求助--关于压电陶瓷分析
[ 本帖最后由 supervb 于 2006-12-20 19:23 编辑 ]
发表于 2005-10-17 17:09 | 显示全部楼层
  1. /TITLE,VM237, PIEZOELECTRIC-CIRCUIT ANALYSIS
  2. JPGPRF,500,100,1 ! MACRO TO SET PREFS FOR JPEG PLOTS
  3. /SHOW,JPEG
  4. /COM, ---------------------------------------------------------------
  5. /COM, FINITE ELEMENT MODEL OF A PIEZOELECTRIC CIRCULAR PLATE
  6. /COM, ---------------------------------------------------------------
  7. A=1E-3 ! RADIUS, M
  8. T=0.1E-3 ! THICKNESS, M
  9. /COM,
  10. /COM, MATERIAL PROPERTIES OF LEAD ZIRCONATE TITANATE (PZT-5A)
  11. /COM,
  12. /COM, -- MATERIAL MATRICES (POLAR AXIS ALONG Y-AXIS): IEEE INPUT
  13. /COM,
  14. /COM, [s11 s13 s12 0 0 0 ] [ 0 d31 0 ] [ep11 0 0 ]
  15. /COM, [s13 s33 s13 0 0 0 ] [ 0 d33 0 ] [ 0 ep33 0 ]
  16. /COM, [s12 s13 s11 0 0 0 ] [ 0 d31 0 ] [ 0 0 ep11]
  17. /COM, [ 0 0 0 s44 0 0 ] [ 0 0 d15]
  18. /COM, [ 0 0 0 0 s66 0 ] [ 0 0 0 ]
  19. /COM, [ 0 0 0 0 0 s44] [d15 0 0 ]
  20. /COM,
  21. /COM, - COMPLIANCE COEFFICIENTS, M2/N
  22. S11=16.4E-12
  23. S12=-5.74E-12
  24. S13=-7.22E-12
  25. S33=18.8E-12
  26. S44=47.5E-12
  27. S66=44.3E-12
  28. /COM, - PIEZOELECTRIC STRAIN COEFFICIENTS, C/N
  29. D15=5.84E-10
  30. D31=-1.71E-10
  31. D33=3.74E-10
  32. /COM, - RELATIVE PERMITTIVITY AT CONSTANT STRESS
  33. EP11=1730
  34. EP33=1700
  35. /COM, - DENSITY, KG/M3
  36. RHO=7750
  37. /NOPR
  38. /PREP7
  39. /COM,
  40. /COM, -- MATERIAL MATRICES (POLAR AXIS ALONG Y-AXIS): ANSYS INPUT
  41. /COM,
  42. /COM, [s11 s13 s12 0 0 0 ] [ 0 d31 0 ] [ep11 0 0 ]
  43. /COM, [s13 s33 s13 0 0 0 ] [ 0 d33 0 ] [ 0 ep33 0 ]
  44. /COM, [s12 s13 s11 0 0 0 ] [ 0 d31 0 ] [ 0 0 ep11]
  45. /COM, [ 0 0 0 s44 0 0 ] [d15 0 0 ]
  46. /COM, [ 0 0 0 0 s44 0 ] [ 0 0 d15]
  47. /COM, [ 0 0 0 0 0 s66] [ 0 0 0 ]
  48. TB,ANEL,1,,,1 ! ANISOTROPIC ELASTIC COMPLIANCE MATRIX
  49. TBDA,1,S11,S13,S12
  50. TBDA,7,S33,S13
  51. TBDA,12,S11
  52. TBDA,16,S44
  53. TB,PIEZ,1,,,1 ! PIEZOELECTRIC STRAIN MATRIX
  54. TBDA,2,D31
  55. TBDA,5,D33
  56. TBDA,8,D31
  57. TBDA,10,D15
  58. TB,DPER,1,,,1 ! DIELECTRIC PERMITTIVITY AT CONSTANT STRESS
  59. TBDA,1,EP11,EP33
  60. TBLIS,ALL ! LIST INPUT AND CONVERTED MATRICES
  61. MP,DENS,1,RHO ! DENSITY
  62. ET,1,PLANE223,1001,,1 ! PIEZOELECTRIC AXISYMMETRIC ELEMENT TYPE
  63. RECT,,A,,T
  64. ESIZE,T ! MESH SOLID MODEL
  65. NUMSTR,NODE,10
  66. AMESH,1
  67. ! APPLY STRUCTURAL BC, SIMPLY SUPPORTED PLATE
  68. NSEL,S,LOC,X
  69. D,ALL,UX,0
  70. NSEL,S,LOC,X,A
  71. NSEL,R,LOC,Y,0
  72. D,ALL,UY,0
  73. NSEL,ALL
  74. ! APPLY ELECTRIC BC
  75. NSEL,S,LOC,Y,0
  76. CP,1,VOLT,ALL ! COUPLE BOTTOM ELECTRODE
  77. *GET,NBOT,NODE,0,NUM,MIN ! GET MASTER NODE ON BOTTOM ELECTRODE
  78. NSEL,S,LOC,Y,T
  79. CP,2,VOLT,ALL ! COUPLE TOP ELECTRODE
  80. *GET,NTOP,NODE,0,NUM,MIN ! GET MASTER NODE ON TOP ELECTRODE
  81. NSEL,ALL
  82. D,NBOT,VOLT,0 ! GROUND BOTTOM ELECTRODE
  83. D,NTOP,VOLT,1 ! APPLY 1V LOAD ON TOP ELECTRODE
  84. FINI
  85. /SOLU
  86. ANTYPE,STATIC ! STATIC ANALYSIS
  87. SOLVE
  88. FINI
  89. /POST1
  90. *GET,QT,NODE,NTOP,RF,CHRG ! GET TOTAL CHARGE ON TOP ELECTRODE
  91. CP=ABS(QT) ! CAPACITANCE CP=Q/V, WHERE V=1V
  92. EPZ0=8.854E-12 ! FREE SPACE PERMITTIVITY
  93. PI=3.1415 ! PI CONSTANT
  94. C=EP33*EPZ0*PI*A**2/T ! ANALYTICAL CAPACITANCE
  95. /COM, 2-D CAPACITANCE (ANALYTICAL) =%C%, F
  96. /COM, 2-D CAPACITANCE (ANSYS) = %CP%, F
  97. FINI
  98. /COM, ---------------------------------------------------------------
  99. /COM, FINITE ELEMENT MODEL OF RLC-CIRCUIT
  100. /COM, ---------------------------------------------------------------
  101. /PREP7
  102. DDELE,NTOP,VOLT ! DELETE VOLTAGE LOAD ON TOP ELECTRODE
  103. ET,2,CIRCU94,0 ! DEFINE A RESISTOR
  104. R=3000 ! RESISTANCE, OHM
  105. R,1,R
  106. N,1
  107. TYPE,2
  108. REAL,1
  109. E,1,NTOP
  110. ET,3,CIRCU94,1 ! DEFINE AN INDUCTOR
  111. L=15 ! INDUCTANCE, H
  112. R,2,L
  113. N,2
  114. TYPE,3
  115. REAL,2
  116. E,2,1
  117. ET,4,CIRCU94,4 ! DEFINE A VOLTAGE SOURCE
  118. V=1 ! VOLTAGE LOAD, V
  119. R,3,V
  120. N,3
  121. TYPE,4
  122. REAL,3
  123. E,2,NBOT,3
  124. FINI
  125. /SOLU
  126. ANTYPE,TRANS ! TRANSIENT ANALYSIS
  127. NSUB,100 ! NUMBER OF TIME STEPS
  128. TIME,2E-3 ! ANALYSIS TIME, S
  129. TINTP,,0.25,0.5,0.5 ! INTEGRATION PARAMETERS FOR A PIEZOELECTRIC ANALYSIS
  130. OUTRES,ALL,ALL
  131. SOLVE
  132. FINI
  133. /GOPR
  134. /COM, ANALYTICAL SOLUTION:
  135. /COM, V_C = 1-EXP(-D*T)*COS(B*T)-D/B*EXP(-D*T)*SIN(B*T)
  136. /COM, WHERE:
  137. D=R/(2*L)
  138. B=SQRT(1/(L*C)-D**2)
  139. /NOPR
  140. /POST26
  141. NUMVAR,20
  142. NSOL,2,NTOP,VOLT,,V_C_ANSYS
  143. ! DERIVE EXACT SOLUTION
  144. *DIM,WORK1,ARRAY,100
  145. *DIM,WORK2,ARRAY,100
  146. FILLDATA,3,,,,1 ! 1
  147. EXP,4,1,,,,,,-D,-1 ! -EXP(-D*T)
  148. PROD,5,1,,,,,,B ! B*T
  149. VGET,WORK1(1),5
  150. *VFUN,WORK2(1),COS,WORK1(1)
  151. VPUT,WORK2(1),6 ! COS(B*T)
  152. *VFUN,WORK2(1),SIN,WORK1(1)
  153. VPUT,WORK2(1),7 ! SIN(B*T)
  154. ADD,8,6,7,,,,,,D/B ! COS(B*T) + D/B*SIN(B*T)
  155. PROD,9,4,8 ! -EXP(-D*T)*[COS(B*T) + D/B*SIN(B*T)]
  156. ADD,10,3,9,,V_C_EXACT ! 1-EXP(-D*T)*[COS(B*T) + D/B*SIN(B*T)]
  157. ! PRINT AND PLOT ANSYS AND EXACT VOLTAGE ACROSS THE PZT CAPACITOR
  158. PRVAR,2,10
  159. PLVAR,2,10
  160. /NOPR
  161. *DIM,VCE,ARRAY,5 ! EXACT SOLUTION FOR RESULTS TABLE
  162. *DIM,VCA,ARRAY,5 ! ANSYS SOLUTION FOR RESULTS TABLE
  163. *GET,VCE(1),VARI,10,RTIME,0.18E-3
  164. *GET,VCE(2),VARI,10,RTIME,0.40E-3
  165. *GET,VCE(3),VARI,10,RTIME,0.88E-3
  166. *GET,VCE(4),VARI,10,RTIME,0.13E-2
  167. *GET,VCE(5),VARI,10,RTIME,0.186E-2
  168. *GET,VCA(1),VARI,2,RTIME,0.18E-3
  169. *GET,VCA(2),VARI,2,RTIME,0.40E-3
  170. *GET,VCA(3),VARI,2,RTIME,0.88E-3
  171. *GET,VCA(4),VARI,2,RTIME,0.13E-2
  172. *GET,VCA(5),VARI,2,RTIME,0.186E-2
  173. *DIM,LABEL,CHAR,5
  174. *DIM,VALUE,,5,3
  175. LABEL(1) = '1.8E-2s','4.0E-2s','8.8E-2s','1.3E-1s','1.86E-1s'
  176. *VFILL,VALUE(1,1),DATA,VCE(1),VCE(2),VCE(3),VCE(4),VCE(5)
  177. *VFILL,VALUE(1,2),DATA,VCA(1),VCA(2),VCA(3),VCA(4),VCA(5)
  178. *VFILL,VALUE(1,3),DATA,ABS(VCA(1)/VCE(1)),ABS(VCA(2)/VCE(2)),ABS(VCA(3)/VCE(3)),
  179. ABS(VCA(4)/VCE(4)),ABS(VCA(5)/VCE(5))
  180. /OUT,vm237,vrt
  181. /COM
  182. /COM,------------------- VM237 RESULTS COMPARISON ---------------------
  183. /COM,
  184. /COM, | TARGET | ANSYS | RATIO
  185. /COM,
  186. /COM, VC for t @ ...
  187. /COM
  188. *VWRITE,LABEL(1),VALUE(1,1),VALUE(1,2),VALUE(1,3)
  189. (1X,A8,' ',F12.4,' ',F12.4,' ',1F5.3)
  190. /COM,----------------------------------------------------------------
  191. /OUT
  192. FINI
发表于 2005-10-17 17:10 | 显示全部楼层
另外可以help VM175 VM176看一下
发表于 2006-4-28 09:25 | 显示全部楼层
系统帮助文件里面有,最好学习命令流,这样跟方便交流,网上很多地方有这方面的例子!上网多找找吧
发表于 2011-10-26 19:22 | 显示全部楼层
GMT+8, 2024-11-29 13:39 , Processed in 0.066485 second(s), 22 queries , Gzip On.
